da9 wire tuck question
when doing a tuck, what where have people put the sensors that are on the firewall??? right side has 2 sensors and the map, left side has a black box whih contains 2 sensors..another question.. is it worth it to put a 94 teg intake mani?...looks cleaner.
im stumped on what have people done with those sensors that i mentioned above.
also. i have my egr on my intake mani by the distributor, where is it on a 94 teg intake mani?
my sensor was mounted under the dashboard and just routed a hose inside for vacuum but you could mount it anywhere like under the intake mani and make a small bracket and just extend the wiring to it.
i dont believe the mt integra have one but from my understanding you can remove them and cap off the line but will throw an engine code unless you have a ecu from a manual to put in
ok, i noticed that behind the firewall on the driverside there is a big empty spot, you think it would be a good idea to mount those sensors in there, ofcourse making my own braket and mount them on that and in there. in where the winshield motor is.
yeah you can mount them anywhere really as long as it doest get hit by moving parts, the other thing is that if you mount it under the cowl where the wiper linkage is thats where alot of water goes when it rains so make sure its covered or chose a different spot
Im in the middle of doing a wire tuck on my 92 db2 right now. The drivers side was easy but that passenger side is no fun. Trying to get the harness through the firewall just plain sucks because of all the crap behind the dash in the way. Looks like i have to get up behind the glove box and remove all the A/C evaporator crap just to reach the grommet location. Good luck with yours.
electronb16si
Jan 23, 2007 08:59 AM
aaronpark
Jun 13, 2006 10:23 PM
Rush
Apr 7, 2005 03:53 AM
