vaccum question....!!!
Old Aug 21, 2004 | 05:16 PM
EG6AAARRR!!!'s Avatar
Default vaccum question....!!!
ok..i finally got pics of my engine bay and there are a few questions i need answerd...one question is there is a vaccum hose that is comming off of a sensor on the fire wall that is not hooked up..i need to know what sensor this looks like and where the hose should be going to...
ok second question...i just got an intake for my car that i believe was made for a crx....the stock intake had one big hose and two little hoses hooked up to it..my new intake has two big holes...i put in the big hose that was on the stock intake and plugs the other hole...ok..for the other smaller two hoses that went to the intake...is it alright if i have them pluged or should i try to drill holes in the intake for them to fit...here are some pics...
one more thing...i have a feeling that maybe one of my spark plug wires is in the wrong spot...does anyone have a pic or a diagram that can show me exactly which wire goes where from the distributor to the valve cover...thanks guys for any help...
Old Aug 21, 2004 | 08:27 PM
Default Re: vaccum question....!!! (88g1tegls)
Old Aug 22, 2004 | 06:13 AM
help please......the pics went out becuase of imagestation update...if anyone can help me please post..
Old Aug 22, 2004 | 08:10 AM
mmuller's Avatar
Mad Scientist
1st pic, i dunno...
as far as the intake, just plug the hole thats left over.
dizzy: it goes 1-3-4-2; starting by the bottom left spark plug connector on the dizzy and hopefully you know that #1 cyl. is the closest to the timing belt
Old Aug 22, 2004 | 12:44 PM
JDMorgan's Avatar
Default Re: vaccum question....!!! (mmuller)
you can take off the thing attached to the throttle wheel and mounted by 2 screws to the tb. it doesnt do anything anyways, also if you want to get rid of the metal tube thing that went to ur stock intake, you can take it out and either cut a piece of the antifreeze side making a coupler or use a vacum coupler you can buy at autozone cheap.
i dont know what the thing is in the first pix but what i would do is unplug the tube going to nothing and as long as everything still works keep it like that.
Old Aug 22, 2004 | 03:36 PM
Default Re: vaccum question....!!! (KraZEtEggIE)
Old Aug 22, 2004 | 06:02 PM
ttt
ilovemyh22
Dec 23, 2009 09:14 PM
lysergide
Apr 18, 2006 06:50 PM
EG6AAARRR!!!
Aug 23, 2004 01:09 PM
shermanator
Mar 9, 2004 07:31 PM
Starrman85
Dec 17, 2002 08:45 PM
