Overheating problems
Old Sep 24, 2013 | 03:38 AM
Flipmonkey's Avatar
Default Overheating problems
I have a 94 LS that overheats whenever I come to a stop . My temp gauge usually goes passed half way mark but never to H . When I'm at a stop and raise my rpms it would go back to normal . My coolant reservoir empties out in about 2weeks . But I don't see any leaks of coolant at all . What could be causing my temp to rise ? Where is my coolant going ? What do you guys think ?
Old Sep 24, 2013 | 10:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: Overheating problems
Does rad fan turn on?
Overheating when you come to a stop is a symptom of a non working rad fan.
If the engine overheats at speed when you drop RPM to an idle, [press clutch and coast], the problem is the water pump.
If temp. drops when engine is revved when stopped, it is a symptom of a bad water pump.
You may be losing coolant at the pump, you would not see it.
If the pump is the original one, it is past due for a new one, along with timing belt and possibly timing belt tensioner. 94
Old Sep 30, 2013 | 06:54 PM
Flipmonkey's Avatar
Thanks fcm . That does make sense . I didn't think of that . I just thought of thermostat and radiator fan . Both my radiator fan and thermostat work fine
eman96
Nov 27, 2014 07:08 PM
MikesEJ1
May 13, 2012 03:13 PM
NOTUNINGNONADA
Jul 18, 2010 06:28 AM
da_33
Nov 30, 2006 08:29 PM
