How to remove alternator from EJ6 w/ Y7
Old Aug 2, 2012 | 01:33 PM
david420's Avatar
Default How to remove alternator from EJ6 w/ Y7
As title says I have an EJ6 w/ stock y7 and am trying to replace alternator.
I have no problems unblolting/disconnecting anything but I can't get the damn thing to come out!
Im assuming im going to have to remove some things but id rather not just tear everything out when there might be an easier way.
I am thinking im going to have to remove either brake master or driver axel.
Btw I have searched and watched videos but they dont seem to help me. If anyone has any tips for removing it(from bottom or top?)
Any help would be much appreciated.
Old Aug 2, 2012 | 01:34 PM
98civdx's Avatar
Master Detailer
Default Re: How to remove alternator from EJ6 w/ Y7
Pull the axle, drop the alt. from bottom.
Old Aug 2, 2012 | 01:37 PM
david420's Avatar
Is this the only way? Ive never removed an axle, is it relatively simple with a little bit of research?
Old Aug 2, 2012 | 01:49 PM
redm3turbo's Avatar
it aint bad as long as your underside bolts aren't full of rust.
if you got an impact wrench poppin an axle out is a 4 minute job. If your twisting the wrench, make sure you got pb plaster on hand along with a torch
Old Aug 2, 2012 | 01:54 PM
david420's Avatar
Well i dont think they are too rusty its a NC car so just average i guess. My problem is i dont have an impact and i dont even have the right socket for axel nut, its 1 1/4 right?
I thought there was a way from the top as well?
Old Aug 2, 2012 | 02:10 PM
david420's Avatar
Should bought an EG FML!!!!
Old Aug 2, 2012 | 02:17 PM
98civdx's Avatar
Master Detailer
we had to remove the axle on my freinds 94 ex. So I'm not sure how it would matter...
any ways, you don't need an impact. All you need is a breaker bar, and a cheater pipe.
the axle nut is 32mm
Old Aug 2, 2012 | 02:20 PM
david420's Avatar
Oh, i was just saying that because i just watched two vids, one with a guy with a y8 and one with an eg and they both slid them from the top somehow like it was nothing. I guess i will be walking to advanced. Thanks for all the help from everyone.
Edit: No one has removed the BMC to do this?
Last edited by david420; Aug 2, 2012 at 02:21 PM. Reason: No one has removed the BMC to do this??
Old Aug 2, 2012 | 03:30 PM
98civdx's Avatar
Master Detailer
I would NEVER remove the BMC to do this.
Not sure how he got it out from top. we tried so much **** before I got pissed off and yanked the axle. lol
Old Aug 2, 2012 | 04:29 PM
david420's Avatar
After much debate i decided to just pull the BMC and it worked like a charm. I only had to move the BMC a tiny amount to squeeze the alt through. Is there a reason you are so against this method?
Edit: If you are really curious go on youtube and search "how to remove alternator from 96 civic. He had a y8 though, or atleast y8 IM.
Last edited by david420; Aug 2, 2012 at 04:30 PM. Reason: If you are really curious go on youtube and search alternator removal 96 civic and you will see.
91akira
Aug 15, 2017 05:12 PM
tigueremalo
18
Jun 2, 2007 11:41 PM
RA61825
12
Dec 22, 2005 01:04 PM
ljoe
Nov 24, 2003 10:43 AM
Shft@9GSR
Nov 23, 2002 08:05 PM
