Strut Bar Rubbing Map Sensor
Old Aug 2, 2012 | 08:22 AM
houghton's Avatar
Icon2 Strut Bar Rubbing Map Sensor
I just put a DC front strut bar on my 95 Del Sol with a JDM B18C Type R motor and trans. It is touching/squishing my MAP sensor. Causing excess vibratins into the cabin at some points of diving. (i have the edelbrock 65mm throttle body also)
I am going to replace the intake manifold with a Performer X which sits back a little further and will push the throttle body back and out of the way.
Recently my finances have changed so its going to be at least a month before this happens.
Would it be ok to
A) leave it as is and deal with the heavy vibes
B) Shave a bit of the top of the MAP sensor off to fit (like 3-4mm)
C) Put steel spacer washers over the 2 bolts to move the bar up just enough
I am affraid of putting the washers there because the strut bar base will not sit flush on the strut tower and I feel it might bend the bolts on my struts (which are apexi and i dont want to mess them up)
Total spacing will be 1/4" with washers.
Thanks guys.
Old Aug 2, 2012 | 08:27 AM
kyden's Avatar
Default Re: Strut Bar Rubbing Map Sensor
remove the bar?
Old Aug 2, 2012 | 08:30 AM
houghton's Avatar
well I would like to keep it on there. Wondering if it is going to cause any damage to anything for the next month if I leave it on as is. Or if I can perform one of the above listed solutions in the mean time.
Removing the bar is defintiely an option but I would like to keep it installed if problems wont occur.
Old Aug 2, 2012 | 08:36 AM
JuggerNaut-CTR's Avatar
Old Aug 2, 2012 | 08:51 AM
houghton's Avatar
Looking for information like will extra stress on the throttle body bolts/studs damage anything and if that is putting excess stress on the intake manifold bolts/studs. It is a very very little amount of pressure. For my motor mounts one bushing is not solid on the drivers side of the vehicle, the rest are solid bushings (that is the way it came) so the motor does not move much at all to begin with.
I was trying to get informed on the subject, please keep non helpful comments to your self to reduce flame clutter in this thread.
Old Aug 2, 2012 | 09:26 AM
mayfly's Avatar
just remove the bar. no sense in griding important pieces.
Old Aug 2, 2012 | 10:12 AM
You were trying to get informed on common sense. :yesnod:
Old Aug 2, 2012 | 10:16 AM
houghton's Avatar
thanks.....
Old Aug 2, 2012 | 10:18 AM
your welcome.....
Old Aug 2, 2012 | 10:21 AM
houghton's Avatar
now to add it to the 'soon to be installed but sits in my closet' parts pile
Old Aug 2, 2012 | 11:49 AM
StreetsideStig's Avatar
Remove the bar, bro. It's only a month, and it's not worth risking a pricey new MAP sensor.
Old Aug 2, 2012 | 12:42 PM
Magik8252's Avatar
Would it be ok to
Thanks guys.
I thought the squishing parts was very funny. If you have the money just buy a new map sensor and keep it on reserve so when your map sensor does go out from being squishy, youll be all set.
All kidding aside I would get rid of the bar for time being.
Old Aug 2, 2012 | 02:54 PM
cryptonik's Avatar
I'd just put some washer's under the mating surfaces depending on how bad it's rubbing.
Old Aug 2, 2012 | 03:21 PM
Deetz's Avatar
Crazy Honda Guy
Exactly whay i was thinking, should be an easy solution
Old Sep 12, 2012 | 06:06 PM
houghton's Avatar
removed bar and all of its sexiness.
Wanna sell it or trade it for a 3 point strut bar.
Spent intake manifold money on AEM oil pressure and wide ban gauges along with a custom pod and all fittings to keep dummy oil light.
I need to monitor some possible issues I got going on before I shell out on more performance.
All ideas, thanks a lot for input.
And yes it squished it to death.
RIP old map sensor.
Old Sep 13, 2012 | 02:48 AM
grumblemarc's Avatar
The Grumpiest
Without pictures it sounds to me like it's installed backwards.
Old Sep 13, 2012 | 06:47 AM
houghton's Avatar
installed
MAP sensor
Old Sep 13, 2012 | 07:26 AM
kyden's Avatar
why you would go through that problem just for a stupid strut bar is beyond me.
it also doesn't help that you're not running torque mounts with oem motor mounts.
Old Sep 13, 2012 | 07:30 AM
houghton's Avatar
Didnt notice issue until it was installed, now I'm stuck with the part in my closet for the time being.
The drivers side motor mount is the only one that is not a poly bushing, thats the way it was when i purchased it. Hasport mounts are in my future.
Is that what you meant by torque mounts?
Old Sep 13, 2012 | 07:32 AM
The Grumpiest
So you're running a strut bar that is incompatible with your swap. You are changing out the IM in a month. So WTF would you not just run without the bar until then?
I'm sorry but that would seem to me to be plain common sense instead of trying to rig up some half baked solution.
Old Sep 13, 2012 | 07:45 AM
houghton's Avatar
I did remove the bar. The general opinion was common sense to remove it. I have already replaced the MAP sensor.
Its back to the way it was, barless.
Intake manifold is on hold for most likely some time now. Seems in my best inerest to have that done with the headwork im saving for.
In the meantime I am having some possible oil pressure issues and my tune keeps reverting to a very rich state. (possible computer issue from previous moisture problems)
Installing AF gauge and oil pressure gauge today to get an idea of whats going on.
DC2 Mang
Jul 28, 2006 12:10 AM
8atman
12
May 30, 2006 08:04 PM
crazy eyez killa
22
Feb 26, 2004 09:44 PM
0-60n4
May 23, 2002 03:58 PM
0-60n4
May 22, 2002 07:39 AM
