EG B18A/B Bogging down
Old Jul 31, 2012 | 08:26 PM
Crazed_T's Avatar
Default EG B18A/B Bogging down
Okay so here we go. I bought this car with a blown headgasket. Got it all tore apart and found the head was warped. I read around and found that the B18B head would fit bolt on and it did for the most part. I finally got it in time mechanically and I'm pretty sure the ignition timing is too. When I go to pull out it revs up nice, but has no speed. It idles rough like a ?loping? sound. At idle it shakes the whole cash and steering wheel. Also it back fires at idle. I'm not sure what to make of it. I've never really been a "honda guy" but I figured I'd try out one. This is kind of changing the way I feel about them to the worst.
Old Aug 1, 2012 | 08:11 AM
Crazed_T's Avatar
Default Re: EG B18A/B Bogging down
Really? Nobody? Also not the IAC, I switched it out with a known good one that is clean, same thing.
Old Aug 2, 2012 | 03:42 AM
blackEXcoupe's Avatar
Its your timing. More than likely your 1 tooth off. Pull ur crank pully, turn NO.1 to TDC, The mark on the crank gear should line up with the mark on the oil pump. The marks on your cam gears should line up with each other (google it). Throw the belt back on. If your not experienced, its an easy mistake to make.
Old Aug 3, 2012 | 07:03 AM
Crazed_T's Avatar
I have had the belt of at least ten times. All the marks are dead on.
Old Aug 6, 2012 | 01:48 PM
Crazed_T's Avatar
nobody else?
mysuperslowej1
Aug 30, 2012 02:38 PM
kcvi3tstyl3
Aug 1, 2010 09:01 AM
SOHCMAN
May 31, 2005 03:10 PM
Used2beAb16
May 25, 2004 07:55 AM
snoop_bealybob
Apr 25, 2003 12:45 PM
