Suspension & Brakes Theory, alignment, spring rates....
gsr brake swap on 92 civic cx
Old Jul 31, 2012 | 11:28 AM
codrulz's Avatar
Default gsr brake swap on 92 civic cx
So i'm planning on doing a complete brake swap (front and rear) from a 94 gsr onto my 92 cx . I've got mixed results on a few things and wanted to clear them up. Do i need the prop valve from the integra? Also the booster and master cylnder from the integra too?
Old Jul 31, 2012 | 11:55 AM
Jgreen94's Avatar
Default Re: gsr brake swap on 92 civic cx
You need the 4040 proportioning cable from the integra, your upgrading from 9.5 to 10.3 in the front stock should be fine. Read up on brakeExperts thead. https://honda-tech.com/forums/suspension-brakes-54/brakeexperts-brake-chart-thread-civic-brake-upgrades-ef-eg-ek-integras-3044628/ hope this helps
Old Jul 31, 2012 | 12:55 PM
codrulz's Avatar
so after reading that thread i see i need the prop valve like you said . i also saw it says i need a 97-01 integra ls master cylnder. will this mc bolt up to my stock booster?
Old Aug 6, 2012 | 03:10 AM
Jgreen94's Avatar
Yes it will
Old Aug 6, 2012 | 03:28 AM
94EG8's Avatar
Seagull Management
No it wont. '94 - '97 Integras will have the ears rotated 90° '98 - '01 Integras have the ears completely horizontal. Either get a '94 - '97 RS master cylinder and brake booster combo or get a '90 - 91 Civic EX MC that bolts up your current brake booster.
Old Aug 27, 2012 | 01:10 AM
Tkrizz's Avatar
What would be wrong with the 98-01 rs mc and bb combo?
Edit: Just re-read his question and didn't see that. The 98-01 rs mc and bb combo will work but why do it when a 91 civc ex mc will bolt to the stock bb. That would just cost more. The lines would match but it won't bolt to the bb.
Old Aug 27, 2012 | 06:58 AM
kyden's Avatar
your lines wouldn't match.
Old Aug 28, 2012 | 09:11 PM
Tenzo's Avatar
Nice to see someone else doing this to their EG as well. I'm in the middle of doing mine, same car as yours.
So yes you'll need a 40/40 prop valve. Got mine on ebay for like 20 bucks.
As for the master cylinder and brake booster, I bought the gsr master cylinder thinking it will line up with my eg brake booster, turned out I needed to find an integra brake booster to line up the m/c.
Old Aug 28, 2012 | 10:23 PM
got-vtec?'s Avatar
you'll also need a non abs brake booster if im not mistaken
Old Sep 3, 2012 | 02:35 PM
Tenzo's Avatar
Oh btw, so I found out that the integra prop valve will not line up with the eg one... the brackets are different. EG is a T shaped one, and the integra is a 2 stud bracket that wont extend as far as the eg. Lol... my solution: Steel wire + ziptie + nut to lock it in stud. LOL. Ghetto af, I know, but I dont want to buy another prop valve just because it wont line up.
Old Sep 4, 2012 | 07:20 AM
kyden's Avatar
i think you got the wrong prop valve.
Old Sep 5, 2012 | 11:40 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Don't swap your prop valve!!! There is a lot of misinformation on this. Upgrade your MC and brake booster! I just put integra brakes on my 94 vx which I did a GSR motor swap earlier this year. It stops great, the only down fall I currently have is the long pedal travel which will be fixed when I install my new MC and BB.
Old Sep 5, 2012 | 03:07 PM
abs0Lut's Avatar
Yeah I did a brake swap and never touched the prop valve, has been braking perfectly fine for a year now in my EG.
Old Sep 10, 2012 | 05:13 AM
Jgreen94's Avatar
Can't you just take the bracket off the eg one and bolt to the integra one?
Somalie187
Suspension & Brakes
Jun 27, 2011 09:16 PM
WHITE DEATH
Jul 5, 2006 10:12 PM
crush
Oct 20, 2005 07:20 PM
mz3bo
Dec 20, 2002 12:05 PM
