Check Engine Light won't turn off!!
Old Jul 29, 2012 | 12:58 PM
grunt111's Avatar
Default Check Engine Light won't turn off!!
Alright so after 2 hours of searching and troubleshooting i still can't get the CEL to turn off. 95 civic ex swapped the gauge cluster and got some old cel codes then cleared them by removing the neg battery cable after also reseting the SRS light that used to be on all the time with the paper clip trick. Now the cel only does non stop long flashes while its under the paper clip and it just stays on solid without the clip. Tried swapping the ecu with a p28 chipped ecu from my b16 hatch and turned the key with out turning the motor over and still the same thing! i'm stomped here any help?
Old Jul 29, 2012 | 01:29 PM
92lxsleeper's Avatar
Default Re: Check Engine Light won't turn off!!
what are the codes for?
Old Jul 29, 2012 | 01:40 PM
grunt111's Avatar
the codes were IACV and tps but i didnt see them before since the cel bulb was not present on the messed up gauge cluster. The codes have not come back since reset so it must have came up when i was trouble shooting my jacked up honda famous up and down idle. Now the cel just has long infinite flashes and solid without the clip. The cel issue i have now all started once i reconnected the neg battery cable.
Old Jul 29, 2012 | 02:02 PM
JuggerNaut-CTR's Avatar
Is this thread real....wait...am I dreaming?
Your old messed up guage cluster had no cel bulb...new one does. Now the check engine light is on. Because really it was all along. You jump the connector and see it flash, thats what its supposed to do, its giving you the code(s)... stays solid when not jumping connector, thats what its supposed to do...its telling you theres a problem. You had those problems all along dude.
Fix the cel's.
Check iacv plug/wiring w/ mulimeter. Clean or replace iacv if neccessary.
Same with the tps.
Old Jul 29, 2012 | 02:17 PM
grunt111's Avatar
I know for a fact that i disconnected the iacv and the tps while the car was running like a week ago while troubleshooting so it would make sense for me to come up with these codes once i put the bulb in, the thing is that the codes have not come up again since i reset the ecu. Now when i jump the service connector all i get is non stop long flashes wich mean what? I checked all fuses, cleaned the ground wire at the thermostat housing and cleaned the neg batt cable ground contact.
Old Jul 29, 2012 | 02:44 PM
as long as the CEL is not present with the clip un jumpered you are golden :D
Old Jul 29, 2012 | 02:51 PM
grunt111's Avatar
Yeah well i guess i'll see if maybe the light goes out eventually with a couple of drive cycles cause it just stays on solid while its not jumped this is some bull shet.
Old Jul 29, 2012 | 07:25 PM
motoracer951's Avatar
i have a 93 civic EX, just got it a few days ago, and my cel is on too, it just started today... i'm gonna scan it tomorrow, and go from there. If i have any more problems, you guys will be hearing from me agian... lmao
Old Jul 29, 2012 | 07:43 PM
oscalito's Avatar
i have a typeR boosted and befored i did it turbo i had the proble and i check it it was just flasingh and non stop and i tried everythig and nothig but i wen to the auto parts and but a cling thing for the ingertors and changed the fuel thig that throws fuel to ur fuel rail and it went away did not came back i dont know the name of the clining ingectors but the bottle is withe
Old Jul 29, 2012 | 07:44 PM
are you talking about sea foam?
Old Aug 2, 2012 | 05:48 PM
grunt111's Avatar
******Update******
Picked up an auto P28 virgin ecu that i personally pulled from a 93 civic ex AUTO from a salvage yard today. Hooked it up and what do u know.. The check engine was on and finally was throwing codes. The codes were the obvious #19 transaxle lock up solenoid and a new one the #19 o2 sensor. But the whole time the car gained an instant idle surge like the quick up and down ones like when u have air bubbles in the coolant. Hooked the other ecu that keeps the cel on and no codes to show and the idle surge goes away. What in the hell?!!!
Old Aug 22, 2012 | 06:34 PM
grunt111's Avatar
How do i check continuity from the o2 sensor to te ecu? i just got a new denso for it and the cel is still on.
Old Aug 23, 2012 | 01:15 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Aug 23, 2012 | 07:58 PM
grunt111's Avatar
Thanx for caring i'll check this stuff tomorow. What i know for sure is that i checked all my fuses ans the problem started once i disconnected the neg battery post and reconnected it.
Old Aug 24, 2012 | 04:13 PM
grunt111's Avatar
Damn, messed with this deal all day and still nothing. Its definately something in the wiring!
Old Aug 29, 2012 | 05:44 PM
grunt111's Avatar
Ok folks so I finally broke down= (let somebody else try to look in to it) and took the civic to a local shop. Paid a total of $178.00 bucks and according to them it turned out to be a faulty Air temp sensor on my d16z6 right behind the intake maniforld that was shorting out causing the o2 sensor cel to come on right away. I sure am glad I got to the bottom of this and I thank everybody that tried to help me out with this situation.
Old Sep 1, 2012 | 07:12 AM
delsolintegra's Avatar
Sometimes it pays to see a professional.
Kudos for trying.
It sounded like a tough diagnosis to begin with.
civicboy420
Aug 11, 2014 01:45 PM
Cincinnati4g
Jun 7, 2014 01:25 PM
turbo sol
Apr 2, 2009 05:31 PM
Mr.Death
Sep 16, 2007 02:05 PM
sheBangZ
Aug 31, 2006 06:02 PM
