1996 Honda Civic with GSR Swap - Injector issue
I have a 1996 Honda Civic with a GSR swap, the 2 center injectors are not working.
Histroy :
So, i have a 1996 Honda Civic that i GSR OBD2A.
Here is the history on car, Car came with a single cam d15, and a OBD2B dash harness and Engine Harness that was all chopped up so i decided to put in a 96-98 dash harness and vtec engine harness. I dropped the motor in this week and wired up the Idle Air Bypass, Idle Air Control Sensor, Purge Control Solenoid, and C KF sensor. Ran all wires to ECU pins on connectors.
finally got the car running thanks to RonJ@HT . But now Its running rough and 2 injectors are not working.
Also Had a P1298 cel for the ELD but went away after a few restarts
Histroy :
Yes the 2 injectors have battery voltage going to them and I checked for voltage drop and there is no drop, I will be checking grounds after work today.
Injectors are controlled by the ECM grouding them, battery voltage is constant. So you either have a faulty ECM, or faulty injectors if the wiring is ok.
Injector clips have a proper firing order just like spark plug wires.
List the injector clip ground wire colors for cylinders 1-4.
Will the engine start with starting fluid?
so the car runs a little better but still having issues, when i pull injectors 2 and 3 i still have no change while running.
I rechecked timing and it is dead on. so im back to square one.
Remove the fuel injector and crank engine to watch whether they spray fuel. If so, make sure the injector ground wires properly pin to the ECU connector.
If all is fine, check the mechanical timing and compression test the cylinders.
HondacivDX
Sep 10, 2010 04:12 PM
rick_rabies
Engine Management and Tuning
29
Jul 8, 2009 09:36 AM
Josh22999
Feb 19, 2007 09:19 AM
