Need help identifying this rear swaybar
Old Jul 27, 2012 | 02:14 PM
LKY's Avatar
LKY
Default Need help identifying this rear swaybar
I got this swaybar for free. Been told its for 99-00 usd SI/ cdn SIR Em1.
I tried to fit it in a 97 civic hatch with aftermarket LCA.
But it wont fit. I thought the 99-00 rear sway are interchangeable to the hatch. Its a bit too long from the endlink and mounting point.
I've been told its a 19mm rear sway. =(
pics below:
Old Jul 27, 2012 | 02:18 PM
98civdx's Avatar
Master Detailer
Default Re: Need help identifying this rear swaybar
Definetly doesn't look like a Honda bar. Have you mic'd it? is it 19mm?
Can you take a picture of the end of the bar, where the endlink would go?
Also, Si/SIR rear sway bar is 13mm, not 19mm.
Old Jul 28, 2012 | 12:51 AM
LKY's Avatar
LKY
The rear sway is aftermarket i believe.
Old Jul 28, 2012 | 01:01 AM
CO671's Avatar
Suspension techniques?
Check this guys link
http://www.cardomain.com/ride/335127...back-2d/page-2
Old Jul 28, 2012 | 02:19 AM
94EG8's Avatar
Seagull Management
I'm not sure exactly what it's off of, but it's a front swaybar, not a rear.
Old Jul 28, 2012 | 05:55 AM
The Destroyer's Avatar
This^
Here is another link.
http://www.civic-eg.com/viewtopic.ph...84545878250f2d
Notice the L bracket coming off the LCA for mounting.
Old Jul 28, 2012 | 06:12 AM
CO671's Avatar
edit....I just re-read OP's post and he said it has aftermarket LCA's
Here's a link to read; it's relative to OP's problem
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-hatch-99-cx-sway-bar-2928831/
Originally Posted by The Destroyer
This^
In addition to what you posted I went ahead and did a bit more Googling.
ST official website: http://www.stsuspensions-store.com/p...sway-bars.html
96-00 version: http://www.clubcivic.com/board/showthread.php?t=153097
http://www.motoiq.com/magazine_artic...-sway-bar.aspx
OP I don't know about you but i'm looking at getting the 22mm Progress sway bar for my 99 Civic in a few months
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-progress-22mm-rear-swaybar-install-2874393/
Old Jul 28, 2012 | 07:57 AM
98civdx's Avatar
Master Detailer
Looks like you have a Suspension techniques rear bar. I was thinking that at first, and those endlinks pretty much confirm it.
Old Jul 28, 2012 | 09:26 AM
[B][COLOR="Red"]
https://honda-tech.com/forums/showthread.php?t=2874393
If its a 22mm rear bar your after save some coin and grab an OEM usdm ITR bar (22mm) and save ~$60.
http://acuraautomotiveparts.org/acur...s=&view=normal
Im not sure if id trust a big bar without some reinforcement or if id trust the sheet metal parts w. the Progress kit.
Old Jul 28, 2012 | 04:22 PM
LKY's Avatar
LKY
Thanks guys. I'll look into the details now
CUTTERSPOOL
Suspension & Brakes
Dec 3, 2009 01:46 PM
auto addict
Jul 6, 2008 12:47 PM
Shaguar47
Feb 25, 2007 05:16 PM
wdskuk
Sep 21, 2003 08:17 PM
ichibano
Jul 5, 2002 07:54 AM
