Sway Bar won't fit.
Sway Bar won't fit.
I just got an itr sway bar; when I went to put it on my 2000 Civic EX, I noticed that the endlinks have no place to attach on the LCA. Do I need new LCA's or different endlinks? If you have pics of a sway bar and endlinks, please post them.
Re: Sway Bar won't fit. (ichibano)
wut endlinks do u have? U'll need the 99-00 Si Rear Endlinks to get it to werk. The Rear LCA's on all 96-00 civics have holoes in them for sway bars. Hope i could help.
EDIT: Oh ****, are u talkin bout the front or the rear? If the front, just buy 99-00 Si front LCAs, damper forks, and sway bar assembly
[Modified by , 10:24 PM 7/3/2002]
[Modified by , 10:25 PM 7/3/2002]
Re: Sway Bar won't fit. (:hammer:)
It's the rear bar. I think I have the itr endlinks, sholud I just drill new holes in the LCA's? Alson do I need a bracket or spacer to put betwwen the D-bracket and subframe. Thanks in advance.
do u have holes in the LCAs now? If so just pick up sum Si endlinks, i got mine for $85, ive got the beaks srk which reinforces the subfame, check it out www.beaksproducts.com
here are some very good pics of the BEAKS KIT sway bar from tonyxcom.
should help you to see where everything goes, good luck
https://honda-tech.com/zerothread?id=158241
anyone else have any ideas? I think I'm going to use the itr endlinks and drill new holes in the lca's.
[Modified by SLPR, 8:54 AM 7/5/2002]
B20EF
07-09-2008 04:44 AM
Shaguar47
02-25-2007 05:16 PM
Amuse9
12-30-2002 12:48 PM
