'01 TL brakes shimmy, mainly right side
Any theories on why they are doing that & what it means?
Edit: Okay, I may need to specify a little better. The brakes do work, but not smoothly. It's not as noticeable when I use them very lightly, but when I push down on the brake even moderately, the right side tends to shake. It's kinda bugging me & makes me think that they are trying to wear out.
Last edited by sakuraofthesea; Jul 25, 2012 at 08:19 PM. Reason: Added specifics to topic issue
If your car has compliance bushings on the lower control arm, check those. Not sure if your body style has them or not.
I know the body style right after yours has constant problems with them, just like the TSX does.
I replaced my pad/rotor setup 3+ times on my TSX due to "warped rotor" feedback through the car/steering wheel/brake pad when slowing down.
Finally replaced my lower control arm compliance bushings (which are a joke, wear out in like 20k miles....kind of like the older civics had the rear trailing arm bushings premature wear), and problem GONE! Wish I wouldn't have spent all that time and money on the brakes before checking the compliance bushings.
It also cured my high speed twitching/straight line tracking problem!
track_assassin
11
Jan 26, 2006 03:38 PM
