97 civic with b16a2 with gsr distributor issue
Old Jul 21, 2012 | 04:23 PM
dcsports's Avatar
Default 97 civic with b16a2 with gsr distributor issue
hey guys i tried to search this issue but found nothing but I am having a issue setting ignition timing on my b16 i am using a odb2a gsr distributor stock odb2b si ecu "p2t" honda recommends 16 + or - 2 degrees ... well the highest i was able to adjust to is 14 degrees and will not adjust any higher i am starting to think it is because i am using a gsr distributor???? help!?????
Old Jul 21, 2012 | 04:39 PM
the jdmchop's Avatar
Default Re: 97 civic with b16a2 with gsr distributor issue
nope shouldnt have any problems, tho you need to jump a wire to set timing cant remember which one tho.
Old Jul 21, 2012 | 04:53 PM
Dc4LsTeG's Avatar
EK9
You need to jump the service connector while doing it. You need to set it to 16 degrees btdc
Old Jul 21, 2012 | 05:30 PM
dcsports's Avatar
i jumped the connector before adjusting
Old Jul 22, 2012 | 05:50 AM
dcsports's Avatar
bump help please
Old Jul 22, 2012 | 05:26 PM
dcsports's Avatar
ttt
Old Jul 23, 2012 | 08:10 AM
kyden's Avatar
if your mechanical timing is correct, there should be no reason you can't adjust correctly. are you using the timing light correctly? i am assuming you are using a digital one since you said 14 degrees. are you using the lone white mark?
Old Jul 23, 2012 | 09:15 AM
98civdx's Avatar
Master Detailer
It's kind of a long shot, but is your mechanical timing correct?
Old Jul 25, 2012 | 03:10 PM
dcsports's Avatar
yea i just did a valve adjustment and checked timing
Old Jul 25, 2012 | 08:30 PM
dcsports's Avatar
anyone ttt
prodjay10
11
Mar 28, 2015 09:07 PM
madmortar
Jun 12, 2008 01:24 AM
allnaturalb16
21
Aug 14, 2007 08:57 PM
brusk13
Jan 11, 2006 07:01 PM
