97 civic with b16a2 with gsr distributor issue
hey guys i tried to search this issue but found nothing but I am having a issue setting ignition timing on my b16 i am using a odb2a gsr distributor stock odb2b si ecu "p2t" honda recommends 16 + or - 2 degrees ... well the highest i was able to adjust to is 14 degrees and will not adjust any higher i am starting to think it is because i am using a gsr distributor???? help!?????
Re: 97 civic with b16a2 with gsr distributor issue
if your mechanical timing is correct, there should be no reason you can't adjust correctly. are you using the timing light correctly? i am assuming you are using a digital one since you said 14 degrees. are you using the lone white mark?
allnaturalb16
21
08-14-2007 08:57 PM
94gsr
10-24-2002 04:15 PM
