Honda CR-V & Element 2WD & 4WD Element & CR-V
Prop Shaft Removal
Old Jul 21, 2012 | 07:48 AM
vwtohonda's Avatar
Default Prop Shaft Removal
Has anyone done this on the crv? If so, how is it done? I am in the process of removing my transmission as we speak, and the manual says remove prop shaft, but trying to get a wrench or socket on these 4 bolts is hard enough, and once on, the whole shaft spins. And tips hints or clues??
Old Jul 21, 2012 | 07:49 AM
vwtohonda's Avatar
Default Re: Prop Shaft Removal
PS 1999 CRV AWD (of course)
Old Jul 21, 2012 | 08:02 AM
ARMED's Avatar
if you cant use an impact gun...put some type of long bar through the joints....long enough where it would hit the ground or the body so that when you turn it...it would stop it...
or the the double wrench technique
Old Jul 21, 2012 | 08:09 AM
CO671's Avatar
I just had this problem last week and made a thread too, here it is if you wanna read it, there are pictures too.
https://honda-tech.com/forums/honda-cr-v-element-156/propeller-shaft-98-crv-3072534/
What I did, since I didnt' have the car lifted and it was on grass was hammered a lug-wrench and a jack-bar into the ground while they were sticking through the shaft. Then just took my 10mm wrench and turned it, although with more leverage like another wrench (double-wrench mentioned by ARMED above) it would've been easier.
Old Jul 21, 2012 | 08:30 AM
vwtohonda's Avatar
Thanks for the help! It worked!!
Old Jul 21, 2012 | 02:03 PM
ARMED's Avatar
nice
Greatness
Jan 15, 2010 05:21 PM
Rhymenoceros
Nov 22, 2007 12:16 PM
Zalitore
Jun 21, 2007 07:27 AM
chevygonehonda
Jul 27, 2004 10:37 PM
