99 gsr swapped ek hatch vtec problem
Old Jul 18, 2012 | 02:54 PM
rice a roni's Avatar
Default 99 gsr swapped ek hatch vtec problem
So I did a gsr swap on my civic and im using a chipped p28 ecu.
I wired in the vtec and I know it works because it does, you can feel it, hear it blah blah. The problem is, if I am constantly in vtec mode(i set it to engage at 5500rpm), for example first gear to 8200, shift second gear and I'm still in vtec, at the end of second gear my cel light kicks on. Forgot if it was cel 21 or 22 but with the cel on the vtec wont work any more. If i key off and start it again the cel goes away and vtec works again.
Anybody with similar problems? Suggestions? I dont have another handy dandy working vtec solenoid to switch out with.
Old Jul 18, 2012 | 03:06 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 99 gsr swapped ek hatch vtec problem
Suggestion? Set VTEC back to stock.
Old Jul 19, 2012 | 01:43 AM
I'm not seeing why setting vtec back to the original engagement point would do anything. I'm not using the original gsr intake manifold.
Old Jul 19, 2012 | 05:56 AM
The Grumpiest
What does the manifold have to do with VTEC engagement? And maybe finding out FOR SURE what the CEL is that is being thrown. Don't know how anyone is supposed to troubleshoot a CEL when no one knows what it is.
Old Jul 20, 2012 | 04:31 AM
never mind. problem is fixed. jump vtps to vtec solenoid. obd1 would be pins a4 to d6. do not jump vtps to ground...it will cause a cel 21 when you engage vtec.
Posted from Honda-tech.com App for Android
MarkCayabyab
13
Mar 21, 2013 11:02 AM
Tyrant_007
Feb 8, 2008 10:34 AM
mister_ej1
May 23, 2007 09:40 PM
breanna*
12
Aug 2, 2006 09:29 AM
pennies_hatchie
Feb 27, 2006 08:37 PM
