1997 civic speedometer isnt working
Old Jul 18, 2012 | 02:29 PM
Del_Slo_b16's Avatar
Default 1997 civic speedometer isnt working
Hey guys i have a 1997 honda civic hatchback with a b16 swap and im having trouble with my speedometer. I have checked the speed sensor and i got 4 volts out of it and i have replaced the speedometer gauge itself and it still isnt working. Can any1 help me out on what else i should do? IDK what wires to look for. I appreciate every bit of help anyone has. Thank you very much.
Old Jul 18, 2012 | 04:01 PM
anonimogo's Avatar
Default Re: speedometer isnt working
it could be a bad speed sensor because i had problems with it before in an automatic civic. two things would happen with a bad speed sensor. 1 it wouldnt shift right and 2.the speedometer wouldnt work. try a used one and see if it helps.
Old Jul 18, 2012 | 04:32 PM
Ok thanks. I will try that and see if it works.
Old Jul 21, 2012 | 06:29 AM
update: The speed sensor DID NOT fix the speedometer... Any other suggestions on what i should do??
Old Jul 21, 2012 | 11:45 AM
94EG8's Avatar
Seagull Management
Default Re: 1997 civic speedometer isnt working
Did you use a '99 - '00 engine harness when you did the swap? If so that would cause the speedometer to not work.
Old Jul 21, 2012 | 01:26 PM
ej1 rep's Avatar
check the contacts in the sensor, I tryed a bunch of things and even bought a new one and it ended up that the pins in the sensor were corroded and pushed back.
Old Jul 22, 2012 | 10:52 PM
Honestly i bought the car with the swap idk if they used a 99-00 engine harness. also i was getting 4 voltage from the wire going to the speed sensor but i will check the contact again
Old Jul 23, 2012 | 05:38 AM
Former User's Avatar
Any CEL codes? Does the odometer work?
4 volts comes from the ECU. Check whether the Blk/Yel wire in the VSS plug has battery voltage and whether the black wire has ground.
Check fuse 15.
Old Jul 23, 2012 | 07:19 AM
I forgot to mention that the odometer abduction trip meter don't work either. i didn't have any cel but then i realized that the previous owner took the bulb out.....when i put a bulb in the check engine light flashes. i went to get my codes scanned and the reader would not connect....i believe I've gotten screwed pretty bad on this car..
Old Jul 23, 2012 | 10:38 AM
Hey guys i found some wires that werent hooked up and i unplugged the wire that was connected to the speed sensor...the first one has both. the wire i am holding is the one that i unplugged from the speed sensor. The one on the right is the wire that was cut and hanging but it doesnt reach the speed sensor...but it has the orange, yellow/black and the ground wire
the second image is the actual wire that was cut
Sk8NJ91
May 31, 2012 07:18 PM
nickmk3
Transmission & Drivetrain
Mar 28, 2010 04:08 PM
blaze.1
Sep 10, 2009 06:24 AM
ohsnapzafingcu
Sep 11, 2008 04:33 AM
