stock head....
Old Oct 15, 2002 | 09:49 AM
servion's Avatar
Default stock head....
How much boost can a stock GSR head handle safely? I'm planning on sleeving and building my bottom end in a month or two, and I want to know if I should save for headwork of any kind before the rebuild. (yes, I did a search)
Old Oct 15, 2002 | 09:55 AM
PrecisionH23a's Avatar
Default Re: stock head.... (servion)
If you plan on increasing your redline, then performance valve springs and titanium retainers are a good thing to have. By porting and polishing the head youll increase the airflow into your engine, but other then that your block is usually the first thing to go byebye when boosting.
Old Oct 16, 2002 | 03:49 PM
servion's Avatar
Default Re: stock head.... (GudeH23a)
If I have a built block (sleeved, all the goodies) and a stock head (minor pnp), assuming proper tuning, how much can I boost?
Old Oct 17, 2002 | 09:17 PM
servion's Avatar
Old Oct 17, 2002 | 11:22 PM
Vanilla Ic3's Avatar
I don't think you need to worry about the head.. it's the head gasket that might not like the boost.
Old Oct 20, 2002 | 07:15 PM
servion's Avatar
Default Re: stock head.... (Vanilla Ic3)
Ok.. so what would bea good head gasket.. a copper one?
Can a stock head hold 20+ psi?
Old Oct 20, 2002 | 10:37 PM
1.8T_EG's Avatar
... i would suggest either cometic or inlinepro
OT : are you building you head yourself?... or are you having a shop put it together?... the reason i am asking is because i am blowing blue smoke and need my bottom end built up this winter and i was wondering if you recommended any shops in the springs?... hit me up here or on pm and lemme know... thanks...
ekhondahudson
Mar 17, 2014 03:46 PM
delsol8017
Jan 1, 2009 11:01 AM
92LSVTEC
Apr 7, 2007 11:06 AM
aemciv
Jun 21, 2005 05:09 PM
dunkd
Feb 27, 2005 09:12 AM
