Throttle body plate
Old Jul 7, 2012 | 01:37 AM
Fnix's Avatar
Default Throttle body plate
Is the throttle plate supposed to be completely closed during idle? I read somewhere about it needing to be open %9 so that air can get by for the car during idle. Reason I ask because my car will not to start unless I hold gas pedal down. What is the main source of air to the engine during idle? Car is d16y8
Old Jul 7, 2012 | 02:56 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Throttle body plate
There is only one source of air during idle OR any time else. Maybe try adjusting your throttle cable.
Old Jul 7, 2012 | 02:58 AM
MRGRIM's Avatar
R.I.P. Mark
if you have to hold it open sounds like IACV is blocked or dead
its the main source of air at idle
TB plate should be totaly closed at idle
Old Jul 7, 2012 | 02:59 AM
Fnix's Avatar
I adjusted it so that my plate is all the way closed, that is why I am asking if it is supposed to be open to let a little air in.
Old Jul 7, 2012 | 03:12 AM
The Grumpiest
Why?
Old Jul 7, 2012 | 09:36 AM
Former User's Avatar
Originally Posted by MRGRIM
i
Incorrect
Old Jul 7, 2012 | 09:37 AM
The throttle stop screw should never be touched. It is set at the factory. It now may be difficult to ever get the engine to idle correctly without replacing the throttle body.
Old Jul 7, 2012 | 11:10 AM
Fnix's Avatar
I was thinking of just buying an aftermarket TB cause the Previos owner kind of mutilated the current one but I notice aftermarket TB's dont even have the screw.
Old Jul 7, 2012 | 05:50 PM
MRGRIM's Avatar
R.I.P. Mark
Incorrect
It is correct
The TB plate or butterfly should be fully closed as the idle air is controled by the IACV and Idle air bleed screw adjustment
Fully Closed : being that it is closed but with out binding this is why the throttle shaft stop screw is there to adjust it from binding at the closed state
Closed State: being that the TB plate has only 0.001-0.002 clearance from complete seal in the Throttle body bore .. This clearance will prevent the plate from binding / sticking closed
The above does not apply to a Carburetor
Old Jul 7, 2012 | 06:45 PM
It is correct
The throttle plate should never be fully closed. At closed throttle, the plate is about 10% open.
s13hero
13
Apr 17, 2017 09:37 AM
EVS90
Mar 16, 2014 04:27 PM
Fnix
May 11, 2012 09:39 AM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
Shft@9GSR
Apr 15, 2002 11:47 AM
