d16y8 thrust washer install question
Old Jul 2, 2012 | 03:24 PM
crimson97's Avatar
Icon3 d16y8 thrust washer install question
Do I have to remove the motor and take the crank out or would the oil pump bridge hold it in place since there's no space on it for it to rotate into
I'm asking because I can definitely fit a new one in the grove where it goes into in the right direction from under the car with the oil pan off if I take the oil pump bridge assembly off
as well
Hope this makes sense and isn't confusing all help is appropriated thanks
Old Jul 3, 2012 | 07:30 AM
guessohw's Avatar
Default Re: d16y8 thrust washer install question
You should be able to oull the oil pan and may be able to get to it but its going to be some work. The oil pump will deff have to be unbolted to make room and the crank girdle may need to as well. The d16y8 has everything pretty tight in there. Also whats the reasoning for swapping the washer? Motor make a noise or something?
coehonda
May 4, 2010 01:29 AM
redline808
Apr 17, 2009 04:06 AM
spool310
Jun 14, 2008 12:37 PM
JDMCRX
Aug 2, 2007 03:03 PM
Carbonciv
Northwest (Sales)
Aug 25, 2006 07:36 AM
