How to remove fuel line bolts?
I'm trying to change my fuel line for the mpfi conversion. I can get the top service bolt of easily but the second bolt with the flare washer thing wont budge. Any tips on getting this off without stripping it?
This is what I'm talking about:
http://img.photobucket.com/albums/v3...2/FuelLine.jpg
isn't the flare washer one piece with the nut part circled in red?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/firewall-fuel-filter-fitting-size-1274739/
https://honda-tech.com/forums/showthread.php?t=1274739
Didnn't think this thing would be that much of a hassle.
I thought you just put the wrench around the nut and turn it? are you holding onto the flare as well pushing the other way
what about using a wrench around the flare or a vice grip.
change that service bolt for a bolt like on the other side after
The filter has a place for a wrench right under that bolt. You hold one spot while you turn the other. Use a third wrench for a cheater if you have to, it's really not that hard.
Alright so I tried what you said zrickety, and it popped off! I just put an adjustable wrench right there at the filter and used a ratchet at the top.
Thanks! I feel like a noob now lol.
UserX826
10
Feb 21, 2009 10:02 PM
wakaranai
Sep 3, 2008 08:10 PM
