new bearings plastiguage .002
Old Jun 28, 2012 | 09:27 PM
jooky5's Avatar
Default new bearings plastiguage .002
I slapped in some new acl std main bearings and checked with plastiguage. All 5 came in at .002. What can I do?
I did measure all 5 at once with no oil... I believe that is the correct way.
This build is for a bone stock d15z1 and I want to do it right... well the best I can.
Old Jun 28, 2012 | 10:50 PM
Hidenplanvew's Avatar
Default Re: new bearings plastiguage .002
Micro Polish the crank... Check oem specs and run on the looser side
Old Jun 29, 2012 | 06:12 AM
kyden's Avatar
did you even bother to check the codes on the crank and block for your bearing size?
Old Jun 29, 2012 | 01:38 PM
jooky5's Avatar
I don't see how a 20 year old engines specs would help here? BTW they came in at all yellow, which is even smaller than standard. So they would be a even bigger gap. Thanks for all the helpful info.
I think I'm going to recheck, cleaning everything really well. esp bolts and threads. .0005 is all i need so you never know. otherwise I guess I will go OEM blue
Old Jun 29, 2012 | 07:58 PM
jooky5's Avatar
Better now that i cleaned and rechecked. closer to .0017 - .0019. So I slapped it all together.
Old Jun 29, 2012 | 08:01 PM
Dc4LsTeG's Avatar
EK9
You'll be fine
tico
Feb 1, 2013 01:35 AM
GReddy SI
Jun 6, 2012 09:31 PM
PphamEK
16
Jun 22, 2009 05:41 PM
rextec
Oct 18, 2004 01:27 PM
senpai
Jun 6, 2003 09:51 AM
