HELP with ACL bearings!
Old Oct 12, 2004 | 09:19 AM
rextec's Avatar
Default HELP with ACL bearings!
do i need to get my crank resized and/or my block line honed for these to be able to work? i am planning on building the bottom end my self and was just wondering about your experience with these.
Old Oct 12, 2004 | 10:39 AM
ExospeedAMcrx's Avatar
Default Re: HELP with ACL bearings! (rextec)
have you measured the crank and rods already to see what bearing sizes you need?
Old Oct 12, 2004 | 12:33 PM
rextec's Avatar
no. but i do know the acl's are sized to the honda green bearing which are the middle bearing size for honda
Old Oct 12, 2004 | 02:04 PM
RyanEJ8's Avatar
Default Re: (rextec)
Install the ACL's and plastiguage them. If they are off by alot on certain journals then you can replace those ones with OEM. 90% of the time the ACL's are right on.
Old Oct 18, 2004 | 10:44 AM
Mach slo's Avatar
Default Re: (RyanCivic2000)
Just curious, could you guys list in order from loosest to tight the oem bearings color? The chart in the shop manual seemed to indicate that greens were the tightest, but that doesn't seem to make sence. Also if you happen know what the approx size or size difference of the different oem main crank bearings are, that be very useful also.
Cheers,
Old Oct 18, 2004 | 10:57 AM
93lsd's Avatar
Default Re: (Mach slo)
do a search on earl he has put all the hondas bearings thickness on here i saw it a while back
Old Oct 18, 2004 | 01:27 PM
vtec94civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Install the ACL's and plastiguage them. If they are off by alot on certain journals then you can replace those ones with OEM. 90% of the time the ACL's are right on.</TD></TR></TABLE>
do what he said. i just did a rebuild with my b16 and i used acl's and they were dead on with the clearances. i have been running them hard for over 3k miles and i haven't had any problems yet. ACL
Jdm_Ej8_Sedan
Jan 29, 2014 05:34 AM
GReddy SI
Jun 6, 2012 09:31 PM
johnls
Aug 4, 2007 10:47 PM
4EN[sic]
Jul 24, 2007 12:47 PM
black99x
Aug 9, 2006 03:03 PM
