93 Hatch Speedo/odometer not working.
Speedo and odometer aren't working 95% of the time. When it does come on its only when im past 60mph and its 15mpg over approx.
Just took apart the cluster check all the wiring speedo, A2 wire is all good.
Where shall i start?
Speedometer head is probably bad. You can touch all the solder points on the back of the speedo head with a soldering iron and it will usually fix them.
There is a possibility that the vss just happened to give out an hour after i put it in because i did pull it from Pull and Save. Going to try another one then if nothing, ill try that.
Thanks for the help, appreciate it very much.
