A/C Compressor Troubleshooting
Hey friends!
Here is the deal.
I am troubleshooting my A/C system. I have gone through the work flow and I am down to the last item, the FIELD COIL.
The resistance is out of range (4.2Ohms), but I tested it at higher than 68 degrees. Is that relevant?
2ndly, if I turn everything on and lightly touch the pulley end of the compressor, it will engage, get cold, and run fine, until it cycles off and then I would have to do it again.
Does this sound like a problem adjusting the plate would fix, or is it because the magnetic coil is not working properly?
Thank you in advance!
Here is the deal.
Re: A/C Compressor Troubleshooting
Done. The armature plate is bent. It's within spec on one side, but the gap grows larger as it goes around.
I guess replacement is in order. Do I need to do the whole clutch kit, or will I be OK just replacing the armature plate?
Thank you
Thank you
picthis1
11
09-03-2011 09:06 PM
