97 civic dx hatch with ls/vtec swap runs like crap -- bad ecu?
Old Jun 25, 2012 | 01:19 PM
bscotti's Avatar
Default 97 civic dx hatch with ls/vtec swap runs like crap -- bad ecu?
Its an ek with a ls/vtec, i cannot get this pig to run right at all. Every sensor reads 1 volt low
ect-3.5
map-4
tps-.49 idle/4.2 wide open
my car never goes into injector cut and will idle around 12 to 13 air/fuel( i have a wideband)its slow as all can be, the stock d series felt faster.
big piece, i have spent so much money and have tried everything.
Its tuned on chrome using a p28 ecu, its tuned for stock injectors but in order to make the proper fuel i have to run 310 injectors, i have a tune for 310 injectors and it runs way to lean
any one have ideas?
Old Jun 25, 2012 | 01:23 PM
bscotti's Avatar
Default Re: weird TPS ECT sensor voltage drop causing issues
i got a huge list of upgrades- dyno made 130 whp, so depressing
gsr head
s2 valves/springs/retainers
blox intake manifold
s2 70mm throttle body
310 rc injectors
adjustable cam gears
b18a1 block
12.1 comp forged pistons
arp rod studs
p28 ecu
type r lsd
grumblemarc's Avatar
The Grumpiest
Originally Posted by bscotti
my car is very similar. Its an ek with a ls/vtec, i cannot get this pig to run right at all. Every sensor reads 1 volt low
ect-3.5
map-4
any one have ideas?
Get a better tune.
Old Jun 25, 2012 | 02:12 PM
bscotti's Avatar
i have tried several
Old Jun 25, 2012 | 09:18 PM
jbpnoman's Avatar
And that tells us that you haven't taken the car to a tuner to have it professionally tuned. That's what Grumble means. Do it.
Old Jun 26, 2012 | 02:41 AM
The Grumpiest
I'm not talking about Ebay basemaps.
I've never heard of such nonsense. There is no way a tuner would have you running like this.
Old Jun 26, 2012 | 04:35 AM
bscotti's Avatar
yes, thats were my problem is. Even the tuner has no idea about it, i got different tunes made for the engine. they all suck, im trying to find a hondata or something for less than expensive.
could it be a ecu problem?
Old Jun 26, 2012 | 04:40 AM
bscotti's Avatar
Default bad ecu?
my engine runs likes ****. I have been trying to figure out why for sometime. All my sensors are brand new, but heres the problem. All the sensors read low supply voltage, even at the ecu. The ecu is getting proper voltage and proper ground.
my ect voltage is 3.5
tps is.49 closed and 4 wide open
map reads 4
the car idles super rich all the time 12.1 on my wideband, wot fuel isnt bad but when ever i shift gears the fuel drops to 10.1 for a second
car is does not have a turbo
Old Jun 26, 2012 | 04:49 AM
Dc4LsTeG's Avatar
EK9
Default Re: bad ecu?
Do you have a friend with an ecu you could try?
Old Jun 26, 2012 | 05:09 AM
jbpnoman's Avatar
Who is this tuner? Is this person a professional tuner who you are paying to do this work, while your car is on a dyno? You need to take your car to a shop, and have it tuned by a professional. Don't worry about what software/hardware you're running. If you have some guy online cutting chips for you based off stuff you tell him, you're doing it wrong.
Take your car to a REAL tuner, who will put your car on a REAL dyno, and get your car a REAL tune. If the person doing your tuning is having trouble with the difference between stock and 310cc injectors, you need to find someone who isn't stupid.
Old Jun 26, 2012 | 05:10 AM
The Grumpiest
You don't get tunes "made". You get basemaps burned to chips "made". This is what you are doing. You are by no means tuned.
Old Jun 26, 2012 | 05:22 AM
The Grumpiest
It's your crappy basemaps. /thread.
Old Jun 26, 2012 | 06:51 AM
Former User's Avatar
Related posts merged. Only one thread per topic is allowed.
What exact Civic do you have?
What wire harnesses are you using?
Old Jun 26, 2012 | 09:26 AM
beecee18's Avatar
Default Re: ek with ls/vtec swap runs like crap -- bad ecu?
gonna have to figure something out before continuing to wash your bores down
Old Jun 26, 2012 | 09:35 AM
Red_Army's Avatar
you have an engine problem.
an LS/vtec putting down the same as a d16? something is horribly horribly wrong and i'd find it hard to believe you'll lose 50+ hp in an ecu alone.
even on a straight stock build it should put down WAY more then that.
Old Jun 26, 2012 | 12:06 PM
bscotti's Avatar
its a 97 civic dx hatch
stock wiring harness converted for vtec
obd1 jumper harness for p28 ecu
Old Jun 26, 2012 | 12:08 PM
bscotti's Avatar
Default Re: 97 civic dx hatch with ls/vtec swap runs like crap -- bad ecu?
also another question, at 27 to 31 mph my car shakes under acceleration
no matter how much gas i give it it doesnt change
axles are brand new
halfshaft is brand new
has a type r lsd
wheels bearings are brand new and the rims were re balanced
i heard someone say hasport motor mounts could cause that??? i dont see that true because my d series with hasport mounts was fine
Old Jun 26, 2012 | 12:22 PM
The Grumpiest
axles are brand new
has a type r lsd
One issue at a time.
Old Jun 26, 2012 | 03:53 PM
bscotti's Avatar
i have way to many....haha
Efabe
Oct 19, 2015 02:57 PM
DJ 2501
20
Jun 28, 2013 07:11 PM
jhotboy2nv
11
May 30, 2013 09:44 AM
sleepencivic
Jun 7, 2006 01:11 PM
