B20 low idle
Whats up guys i have a ek with a b20 swap built for all motor that i just bought not too long ago. The problem is when i start the car i have to hold the gas or it will stall only does it for a couple minutes, but then when im driving if i stop at a redlight or something it does it ever so often. Car doesnt have a cat and no o2 sensor i believe. Any ideas what the problem might be?
so you're saying you get no fast idle, correct? sounds like an iacv issue. maybe stuck.
either that, or the ecm is not commanding the iacv to open on cold start up. in which case the ect sensor may be faulty
do you have access to any datalogging capability? cuz that would be excellent if you did
EJ1A1
Jan 6, 2017 12:07 PM
