poor man 5 lug conversion rear setup
Old Jun 25, 2012 | 01:01 PM
pinoyboy204's Avatar
Default poor man 5 lug conversion rear setup
hey everyone. i recently did the poor man 5 lug conversion on the front. now i'm having trouble finding out what parts i need for the rear.
can i use existing cx rear trailing arm and install rsx-s hub and caliper, rotor, ebrake cable etc to the rear? let me know guys!!
btw its a 96 civic hatch...
Old Jun 25, 2012 | 01:55 PM
GSR CRX's Avatar
Default Re: poor man 5 lug conversion rear setup
you will have to have at least a rear disc setup. if you have rear discs then you should be able to retain your e-brake cables. to do the swap you will need the BB6 rear hub, mazda axle nut, itr rear rotor and caliper.
check out the posting that has been covered before.
https://honda-tech.com/forums/suspension-brakes-54/5-lug-conversion-using-4-lug-spindles-front-rear-1978033/
ive had this done on my crx for over a year now and i havent had any problems.
Old Jun 25, 2012 | 04:32 PM
redm3turbo's Avatar
isnt a poormans 5 lug just to run spacers? I know its big in the VW community
BongoBennie
Honda Insight & CR-Z Hybrid
May 10, 2019 07:29 PM
Jdm-Beast
Suspension & Brakes
1119
Jul 27, 2015 09:28 AM
delsolo95
May 19, 2012 11:12 AM
4gencivicef9
Sep 15, 2009 09:06 PM
88 EF Hatch
Mar 3, 2009 10:12 AM
