changing muffler 2.5'' to 3'' do i need a retune?
Old Jun 25, 2012 | 11:55 AM
golf-mk3's Avatar
Default changing muffler 2.5'' to 3'' do i need a retune?
i got a full 3'' exhaust with a 2.5'' muffler at the end. im going to be replacing the muffler with a 3'' muffler, mainly because the old muffler looks beat up. will my tune be effected.
Old Jun 25, 2012 | 12:20 PM
sleepencivic's Avatar
Default Re: changing muffler 2.5'' to 3'' do i need a retune?
if you run a wideband on the car you can see if your rich or lean after the swap and go from there
Old Jun 25, 2012 | 12:38 PM
Muckman's Avatar
Moderator in Chief
If you are moving more air then you need more fuel to make more power. Watch your wideband, you will probably be a little leaner now.
Old Jun 25, 2012 | 06:05 PM
SiRCiviC94's Avatar
Doubt it
Old Jun 25, 2012 | 06:14 PM
FlewByU352's Avatar
The muffler portion is not a huge restriction given it is a 2.5" N1 vs a 3" N1. There is restriction no doubt, and it will show up on the dyno. But it is not a major problem until you start really pushing the upper 3 digit HP numbers.
Old Jun 26, 2012 | 06:04 AM
A few years back my APexi muffler had a removable silencer that restriceted the muffler flow to about 2 inch exit from a 3 inch exhaust. When I took it out there was a noticable difference in the AFR's, if you dont have first hand experience keep your 2 cents worth! It will effect the AFR's but not by much!
Originally Posted by SiRCiviC94
Doubt it
Old Jun 26, 2012 | 07:45 AM
EsotericImage's Avatar
Retired Moderator
well, its at the end of the exhaust, i doubt it will make a difference. If we were talking replacing the whole DP exhaust to 3" then yes.
Old Jun 27, 2012 | 04:23 AM
LS AzZkIkr's Avatar
I did the same thing and there was a very small change in AFR's. Nothing worth getting a re-tune over.
Old Jun 27, 2012 | 05:15 AM
wantboost's Avatar
Who is Mr Robot?
As stated, the muffler represents a very small section of the overall exhaust system. If you were going from say 2" to 3" or something similar then you might want to re-tune but with just replacing the muffler the change in air/fuel ratios is negligible. I am assuming of course that you mean just the muffler and not any other section of the exhaust system.
DelSolMarine
Sep 18, 2010 01:18 PM
Ricer no 7
22
Apr 25, 2010 04:58 AM
EF8 D-UNIT
Oct 23, 2006 06:02 PM
I Have an STD
Welding / Fabrication
17
Oct 23, 2006 01:55 PM
streetspeed607
Apr 16, 2004 09:23 PM
