2000GSRTypeR's B18C1 GSR Build
Old Jun 24, 2012 | 08:29 AM
2000GSRTypeR's Avatar
Default 2000GSRTypeR's B18C1 GSR Build
Hello H-T, I am finally going to start my build thread. As some of you know, I have been building a B18C1 GSR for boost. I figured that I will finally start my own build thread so that if I run into any troubles along the way I will have my H-T family to guide me through it. This is what I have so far. This will all be going into my 2000 Acura Integra GSR.
B18C1 GSR STOCK sleeve block
Arias pistons 10.2 to 1
Eagle rods
ACL rod bearings, main bearings, and thrust washers
Moroso oil pan
Hasport motor mounts
Golden Eagle head studs
Golden Eagle piston oil squirter plugs
Gates blue racing timing belt
B18C1 GSR head
3 angle valve job
Supertech valves, springs, and retainers
Skunk2 cam gears
Skunk2 Tuner1 cams
Victor X intake manifold
GO-AUTOWORKS 68mm throttle body
GO-AUTOWORKS intake manifold gasket
GO-AUTOWORKS cam seal
98 spec JDM Type R transmission with the factory lsd and 4.78 final drive
ACT 6 puck sprung disc
ACT Extreme pressure plate
ACT Street 12.5lb flywheel
SynapseTurbo ram horn turbo manifold flanged for a 2 bolt 38mm wastegate
SynapseTurbo dump tube
Spoolin Performance 3 inch down pipe
Tial 38mm 2 bolt wategate
Tial 50mm BOV
GO-Autoworks GT half size radiator with -6AN return
GO-Autoworks slim line fan and fan shroud
GO-Autoworks intercooler piping kit
GO-Autoworks 4 inch inlet turbo air filter
TheShodan Interceptor turbo
TheShodan Garrett intercooler
B&R Fittings turbo oil feed kit
B&R Fittings turbo oil return kit
B&R Fittings turbo coolant line kit
B&R Fittings back of the block with return catch can
Hondata S300 in a P28 with BBG and Mac solenoid
AEM UEGO Wideband
SpeedFactory red 4 bar map sensor
ID1000cc injectors
Walbro 255 fuel pump and install kit
OBD2 plug and play harness for the ID1000cc injectors
All positive and negative comments welcome.
Old Jun 24, 2012 | 08:58 AM
Dc4LsTeG's Avatar
EK9
Default Re: 2000GSRTypeR's B18C1 GSR Build
Our builds are pretty similar. Especially if you end up getting the Wolverine, is that what you want the most? You said youll be on 2 tunes correct? Pump and c16?
Old Jun 24, 2012 | 09:07 AM
Yes, I am almost positive that I will be getting the Wolverine from Mac. Yes, I will be using two tunes. One on 93 and another on C16 sir. As I stated in your thread sir, I am just waiting to get my head back from the machine shop so that I can get her up and running.
Old Jun 24, 2012 | 09:16 AM
Old Jun 24, 2012 | 09:52 AM
TheShodan's Avatar
Moderator
ooooo.. pics of the car.. pics of the car!!!
Old Jun 24, 2012 | 01:32 PM
Old Jun 24, 2012 | 01:40 PM
Here is an old pic of the car sir. The car has been sitting in the driveway since December and it is very dirty at the moment. I will upload some new pics as soon as I have the chance sir.
Old Jun 25, 2012 | 12:54 AM
rich7777's Avatar
Nice build man, I'll be following this.
Old Jun 25, 2012 | 04:13 AM
Thank you sir.
Old Jun 25, 2012 | 05:27 AM
I have a GO-AUTOWORKS 68mm throttle body and of course the Victor X opening is only 65mm, what is the best method/process to port match them?
Old Jun 26, 2012 | 08:08 AM
Anyone? I have searched and I have watched the Skunk2 video on how to port match but I just want to make sure that I will be doing it right. I talked to my guy at the machine shop and he stated that when port matching the throttle body to the intake manifold the intake manifold opening should be tapered. Is this true? I do not want to cause any turbulence. Any help or suggestions will be greatly appreciated. Thanks in advance H-T.
Old Jun 26, 2012 | 08:40 AM
rich7777's Avatar
I think as long as the inlet manifold hole is bigger (or the same size) as the throttle body exit you'll be fine. Its only when the flow of air hits a "step" it caused turbulence with things like this. As for porting it, i'd just make a trace and mark off what needs to be taken off then remove it with a dremel or what ever you have.
Old Jun 26, 2012 | 09:03 AM
Thanks Rich, that is exactly what the Skunk2 video says to do.
Old Jun 26, 2012 | 09:09 AM
rich7777's Avatar
No problem
Old Jun 26, 2012 | 10:47 AM
GEN2 LS's Avatar
Loved
Lug nut and rachet socket creative way to hold up that block on the engine stand haha. Build looks good so far man!
Old Jun 26, 2012 | 10:53 AM
Thank you sir, the bolts are my head bolts too. Haha
Old Jun 26, 2012 | 01:54 PM
Dc4LsTeG's Avatar
EK9
Why not use your transmission bolts? That with the nut from the front fork off your suspension works perfect
Old Jun 26, 2012 | 03:42 PM
d16z6Tcrx's Avatar
What are your hp goals? The 4.7 final is going to hurt you.
Old Jun 26, 2012 | 04:49 PM
400whp on 93 and 550whp on c16. At 8500rpm my 98 spec JDM Type R tranny will top out at 164mph in 5th gear with a 24.5inch tire. That is plenty in the MPH department for me.
Old Jun 26, 2012 | 05:05 PM
TheShodan's Avatar
Moderator
oooo, yea.. 4.785.. lots of acceleration
Old Jun 26, 2012 | 06:47 PM
d16z6Tcrx's Avatar
Who tops out 5th gear tho?????
Old Jun 26, 2012 | 07:47 PM
Dc4LsTeG's Avatar
EK9
Who doesn't
Old Jun 27, 2012 | 06:34 AM
I am not trying to be a smart donkey but why not? The 98 spec JDM Type R tranny will still accelerate faster than any other stock B Series tranny even though if I have to shift into 5th gear.
Old Jun 27, 2012 | 06:46 AM
rich7777's Avatar
I have a spoon 4.69 final drive in my ek9 gearbox and i love it. I don't get this whole "the longer the gear the better " thing. Isn't it more personally preference and application??
Old Jun 27, 2012 | 07:02 AM
Yes it is sir but why would you want less acceleration? Don't we modify our cars to go faster/quicker? If you have a good traction control system(your brain and your right foot, haha) you will be perfectly fine. I mean if your tires are spinning wouldn't it make sense to ease off the throttle?
