2000GSRTypeR's B18C1 GSR Build
#53
Re: 2000GSRTypeR's B18C1 GSR Build
I was waiting ages for My stuff to. Remember "good things come to those who wait "... you'll get there eventually...
#57
Now I know that the topic of catch cans have been beat to death but I am stuck in between these two. Which one does everyone prefer and why please?
http://www.brfittings.com/index.php?...&product_id=51
http://www.brfittings.com/index.php?...&product_id=97
#58
You don't want a drainback. You get contaminated oil draining back into the crankcase that way. Also I would highly recommend two fittings off front of valve cover vs the back of the block. They tend to allow oil to syphon outof the engine
#59
Moderator
When oil is contaminated, its contaminated in the system. Turbo-LS, I'm not sure if you mean this, but your statement suggests that the oil catch can being a drain-back system is the causation of oil contamination. From my experience this is not the case. Is this what you've experienced?
#60
Hehe. i'm the exact opposite. Even one of the owners of B&R is using a drainback system. I too will not use a valvecover version, as that is a simpler way to do this.
When oil is contaminated, its contaminated in the system. Turbo-LS, I'm not sure if you mean this, but your statement suggests that the oil catch can is the causation of oil contamination. From my experience this is not the case.
#61
I think he's referring to when condensation mixes with the oil and turns it like caramel . Then it's fed back to the block and is mixed in with the rest of the oil. I've never had a problem using the drain back myself, but I understand what he's getting at as I've questioned it myself.
#62
Moderator
I'm sure B&R Fittings will chime in to discern the differences.
#63
Condensation that leaks into the oil will just burn off. That is going to happen from normal heat cycles anyways. I think youre more likely to contaminate the oil from the blow by itself, not from condensation from a drain back System...I can def see what youre saying but i really dont think the drain back is that bad. Ive used it for years with no issues. I use the Endyn kit witch still uses a PCV valve, but does drain back. I think its better to get crankcase pressure from the back of the block (the source) If you do use the back a drain back i would just make sure the can itself has a filtered Vent
#64
I've seen and personally experienced milky oil in my catch can and that was an endyn drainback system. i quickly stopped the drainback portion. With that same system i also experienced the catch can literally overfilling with oil on a pass. went valve cove and havent looked back since. everyones experience is different i think
#66
#68
#69
Just got my Gates blue racing timing belt! Now only if I can get my head back from the machine shop this weekend, I can finally bolt my head to my block and get the ball rolling!
#71
#72
I finally port matched my throttle body to my intake manifold. Thanks for reassuring me on the procedure Rich. I think that it came out really good. I will post up some pics when I get the chance.
#74
Sorry guys dont mean to butt in but where can i find this wolverine turno that u guys are talking about.. Ive tried to google it and stuff but nothin but comic crap comes up lol and info would be great thanks.
