Afr reading different
Wideband: innovate mtx-l
Program: Crome pro
Hey all, I am having a slight problem with the Afr syncing together for my Wideband and crome pro. I used the yellow wire and hooked it up to the datalogging wire on the ecu. I went to the settings in Crome and changes the Wideband output to and innovate wideband's output but the readings are still off(I.e. mtxl will read 14.5-15 at idle but in Crome, it reads high 15-16s). Anything ?
Program: Crome pro
Go in where you selected the innovate wideband and change the Lambda offset correction until your gauge and Crome datalog match.
Crome/file/settings/tuner logging - Offset Lambda (+/-) 0.00 (default)
May have found the problem. Hooked up the ground of the wideband to the battery and it seems to have solve the problem. I'm surprised the response time of the innovate is a lot slower than the plx m300 that i've had before.
Infamous war
Engine Management and Tuning
Jul 29, 2012 04:12 PM
