A very puzzling problem..
Old Apr 16, 2002 | 03:26 PM
EJK's Avatar
EJK
New User
Default A very puzzling problem..
Purchased an ECU from Kenji, who's been very helpful! thanks! plugged in his ecu by the aid of his obd2-obd1 harness, and tapped about a 3 in. small piece of wire to the 02 signal so that I can wire my A/F gauge to that wire.
I run my car for about 20 min, and I throw a Code 1. Reseted it again, and
again, "primary o2 sensor"...Spoke with Kenji about the problem and he had
told me to run without the A/F gauge to see if I get a MIL. It's been about
3 days, and not a check engine light had gone off. Does anyone know what can
be causing this? Anyone ever had this problem?
Old Apr 16, 2002 | 03:29 PM
Big Phat R's Avatar
Default Re: A very puzzling problem.. (SLPMDE01)
If you connect any wires - you must always solder. Using crimpable connections will lead to unpredictable results like you are experiencing.
It's been about 3 days, and not a check engine light had gone off.
This makes no sense. English please.
Old Apr 16, 2002 | 03:36 PM
EJK's Avatar
EJK
New User
Default Re: A very puzzling problem.. (Phat Bastard)
Actually, the wire that's tapped in the 02 signal of the harness is soldered. I will solder the af wire end and see if that helps. But I still don't understand how I could throw a code with an AF gauge.
MackSpeed-616's Avatar
where is the Jules pic when i need it?
Old Apr 16, 2002 | 04:12 PM
STOLEN - ITR 98-0652's Avatar
Default Re: A very puzzling problem.. (Mr. Bait-R 616)
English, ************! Do you speak it?
Old Apr 16, 2002 | 04:44 PM
EJK's Avatar
EJK
New User
Default Re: A very puzzling problem.. (ITR 98-0652)
could it be that the A/F gauge is robbing the O2 sensor or ECU of a certain voltage requirement?
Old Apr 16, 2002 | 04:47 PM
pleiades nutz's Avatar
Im sorry but i have too......
He looks kinda like a bebe........Im gonna eat you!!
"Lets maks a deal....you can keep your money .........and I get the bebe *licks lips*"
"mmmm bebe the other other white meat......."
"Im ded secksy loook at myy bodey......(tsss *pinches and rubs nipple*)"
"Heh, he looks like a bebe.....Ive chunks of corn in me **** bigger dan you......I've got a turtle heed popin out.......Ugh im gettin all emotional over here..."
killercrx91
Audio / Security / Video
16
Aug 14, 2009 06:32 PM
wutiteez
Dec 1, 2006 06:06 PM
wutiteez
Dec 1, 2006 03:21 PM
y49crxsi
Feb 4, 2004 03:43 AM
EJK
Apr 24, 2002 01:58 PM
