My Build-Up for FI...Tell Me Your Opinions and Thoughts ;)
Old Oct 14, 2002 | 05:16 PM
mntdewred's Avatar
Default My Build-Up for FI...Tell Me Your Opinions and Thoughts ;)
1998 Honda Civic EX D16Y8 Build-Up
Block
75.5mm Custom Ross Racing Pistons 8.8:1 C/R
Eagle Connecting Rods
Golden Eagle Godzilla Sleeves
ACL Bearings
OEM Water Pump
OEM Fuel Pump
Cylinder Head
Cometic 75.5mm .057" Headgasket
ARP Headstuds
HondaSaver SOHC FI Camshaft
HondaSaver SOHC Springs / Valves / Retainers
Skunk2 Cam Gear
Turbo Setup
Greddy Charge Pipes / Intercooler
Greddy Type-S BOV
MaxRev Manifold / Downpipe
Garrett T3/T04E .48 A/R 57 Trim Turbo
Tial 35MM Wastegate
Earls Oil Feed and Return Lines w/Fittings
Fuel Setup
Walbro 255lph Intank
RC Injectors 550cc
AEM EMS or Hondata S200
... this can't be it?
Exhaust
3" Apex N1 Catback
3" Flexpipe
Hi-Flow Cat
Resonator
Gauges
Autometer: Boost, EGT, Oil Pres., Oil Temp .. any other gauges needed?
Misc
Timing Belt
Assorted Gaskets
Upgraded Throttlebody
ACT Xtreme Clutch Kit
Suspension / Tires
GroundControl Adjustable Coilovers
BFG DR
Z-10 Traction Bars
I doubt that is it. What else do I need that I am missing?
TIA
Old Oct 14, 2002 | 05:39 PM
Mr. Softee's Avatar
Default Re: My Build-Up for FI...Tell Me Your Opinions and Thoughts ;) (mntdewred)
i would get an aftermarket fuel rail / fpr.
Old Oct 14, 2002 | 06:24 PM
tygsr's Avatar
Default Re: My Build-Up for FI...Tell Me Your Opinions and Thoughts ;) (94goldjungsr)
The N-1 exhaust is not a 3"...You will need a better oil pump like from a gsr..go with a high flow fuel rail(1 1/2") and a aeromotive 1:1 fpr..
Old Oct 14, 2002 | 06:32 PM
mntdewred's Avatar
Default Re: My Build-Up for FI...Tell Me Your Opinions and Thoughts ;) (tygsr)
was either that or Thermal
So a brand new Oil Pump for my application won't be sufficient? Hmmm...
Old Oct 14, 2002 | 06:33 PM
b18bturbo's Avatar
You cant use a GSR oil pump in dseries.....
Old Oct 14, 2002 | 06:36 PM
HybridKOOP's Avatar
Default Re: My Build-Up for FI...Tell Me Your Opinions and Thoughts ;) (b18bturbo)
I'd suggest almost a point higher in compression... but thats me.
Old Oct 14, 2002 | 06:40 PM
tygsr's Avatar
GOod to know Viren!
Old Oct 14, 2002 | 06:41 PM
tygsr's Avatar
Maybe I'm blind but I didnt see where you were going to replace your oilpump..
[Modified by tygsr, 3:42 AM 10/15/2002]
Hondarookie93
Oct 30, 2010 04:58 PM
boostincoupe
Apr 7, 2006 05:03 AM
projectTeG
Jun 20, 2004 07:34 AM
B18 CYA
May 22, 2004 11:22 AM
