Another SOHC ninja, up to no good!
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
The manifold is getting ceramic coated tomorrow. The basic setup is:
-stock D16Y8, sans ARP headstuds & AEM cam gear
-Precision SC50, .48 a/r turbo
-ramhorn manifold
-Tial 35mm WG
-Stealthmode oil line kit w/firewall kit (next week)
-3" downpipe & cat (soon)
-RC 550cc injectors
-Auto Meter oil pressure & boost gauges
-Walbro 255lph intank fuel pump
-Greddy Type-S BOV
-GE vacuum manifold
-NRG catch can
-DRAG III FMIC
-ACT HDSS clutch
-Chipped P28 w/USB datalogging cable & Crome (is Pro worth it?)
Hoping for around 230-240whp on 10-11 psi. Around June, I'll be dropping in a built D16Y8 (Wiseco/Eagle/OEM bearings) and hoping for 330whp on pump gas.
I will be upgrading to a full 3" KTeller exhaust eventually, and I'll be ordering some 225/50/15 BFG's too...
Thoughts on how to get the most power out of this setup?
Modified by boostincoupe at 12:17 AM 4/6/2006
are you sure that the HDSS will hold your numbers ? I have the XTSS with 300whp and im affrais that she wont hold lol
when you mean ''sans'' ARP headstuds & AEM cam gear.... do you want to say without... because I wouldnt boost a Z6 without the ARP headstud with all the problem they have to hold boost.
The setup looks nice !!
Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo »</TD></TR><TR><TD CLASS="quote">are you sure that the HDSS will hold your numbers ? I have the XTSS with 300whp and im affrais that she wont hold lol
Word, if you haven't installed it yet I would definately try to get ahold of the xtreeme PP instead of the HD.
I had the HDSS in my turbo d-series and it held well, but I was just around 200 hp. If you are going bigger boost in the future, you might as well go with the XT, then you won't have to upgrade later.
also, let me know if you want my magnaflow muffler... i forgot to bring it to work with me...
also i suggest you sell the HDSS and get a competition clutch stage 4 sprung kit...
its awesome on my boosted d and holds the power!
Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">Manifold looks JB-Welded </TD></TR></TABLE>
It's not. Honestly, all I know is that it's a speed-factor.com manifold, and when my buddy ran it on his setup, it leaked everywhere. So they welded all of the leaks up, and that's why it looks the way it does. I will look into grinding down the welds a little more, I just don't want it to leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">also, let me know if you want my magnaflow muffler... i forgot to bring it to work with me...
its awesome on my boosted d and holds the power!</TD></TR></TABLE>
I still want the muffler, can you do $50 shipped like I mentioned earlier?
I already have the ACT HDSS in the car, for about 2 years now. It's holding fine, I just want to push it to its limits. When I get the built motor in, I'll upgrade to either your clutch or an ACT XTSS.
The setup looks nice !! </TD></TR></TABLE>
What I meant was, it's a stock D16Y8 except for having ARP headstuds and an AEM cam gear.
What do you all think of the ES motor mount inserts? They're about $44 shipped on eBay.
Re: (GITWIDIT)
looks like a solid setup...function over fashion...i wouldn't grind down the welds awhile black on the fmic i polish my intercooler and the smoothen the weld out and it leakd on the back side ...cause me countless hours of diagnosis..motor mount inserts
Re: (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT »</TD></TR><TR><TD CLASS="quote">Gonna be close to maxing out those injectors at 330whp.
Good luck with the new setup, looks good </TD></TR></TABLE>
My buddy made 417whp on his built LS with RC 550's.
Re: (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang »</TD></TR><TR><TD CLASS="quote">
tyler used 1600cc's fnan </TD></TR></TABLE>
No, I'm talking about his old setup with the stock LS head and sleeved LS block. This was about 3 years ago?
Re: Another SOHC ninja, up to no good! (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
Thoughts on how to get the most power out of this setup? </TD></TR></TABLE>Get the zex 59300 cam and build the rest of the head now, and just swap it onto the built motor when that goes in
Re: Another SOHC ninja, up to no good! (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger »</TD></TR><TR><TD CLASS="quote">Get the zex 59300 cam and build the rest of the head now, and just swap it onto the built motor when that goes in </TD></TR></TABLE>
Great Idea because Matt (Zexman) is probably gonna sponsor this event with a contingency prize to the winner
Re: (boostincoupe)
sans means without, avec means with, learn your french Looks like a healthy build, lovin the stock block D
After reading about all the ignition timing issues with D16Y8 heads, I might very well be switching to a D16Z6 head with the built motor. We'll see.
After reading about all the ignition timing issues with D16Y8 heads, I might very well be switching to a D16Z6 head with the built motor. We'll see. </TD></TR></TABLE>
are you talking about mike93boost? other than him, i havent heard any problems.
i cant decide between the 105100 or 105300
Re: Another SOHC ninja, up to no good! (97spooncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic »</TD></TR><TR><TD CLASS="quote">
i cant decide between the 105100 or 105300</TD></TR></TABLE>
No, I'm talking about what every D16Y8 turbo owner deals with, in regards to popped headgaskets and motors.
wow, i didnt know that, i need to research more. thanks for the info.
we should make a turbo-d squad, so many people are rocking them now... in fact, look at my sig
