1991 civic no crank
Hi i was doing a tune up and valve cover gasket. I only changed the plugs though no wires. Afterwards no crank at all but all assecories have power. I checked battery 12and volts. Then 12v. At the starter power wire. And the at the solenoid wire i get .5 volts but when push the clutch in try to start it gets 12v. So i figured starter i replaced it today and no go. This just has me baffled. Any help is appreciated.
I kinda check the fuses ill do that today. And try a new ground location on engine i did disconnect one coming off the valve cover try different location. Last owner shaved and bondod it for somereason. But wierd part is there are ground wires on valve cover?
U guys were right ground the previous owner had it bolted into valve cover moved it the valve cover nut and it's. Alive!!!!! Thanks for the help guys hate troubleshooting electrical
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
OPTION2ek V.2
Jul 18, 2005 10:05 PM
