Victor X Vs. Skunk 2 in turbo Gsr
Old Oct 14, 2002 | 04:32 PM
Acuracy's Avatar
New User
Default Victor X Vs. Skunk 2 in turbo Gsr
wat up guyz?
i have gsr with a skunk 2 manifold and in 2 weeks the car is going into the shop and its getting totally built.
je 10:1 pistons,
eagle rods,
Golden eagle sleeves
crower springs and retainers,
clutch flywheel,
i have type r cams and AEM gears
also its getting a turbo kit with a t3/to4E
3 inch apex N1 exhaust
and with 550cc injectors and accel DFi
everything is getting balances and blueprinted
i guess my question is i havee a skunk 2 and i wanna get the victor X with the secondary fuel rail option and get some 440CC secondaries and use my DFi to controll it...do u guyz think its worth it or should i jus keep my skunk 2 and use jus 550 injectors?...wha u guyz think?
Thanks alot
Travis
P.S- i plan on boosting 15 lbs or so...wanna make some serious power but stay safe as well.
Old Oct 14, 2002 | 04:47 PM
LOwrestling2001's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (Acuracy)
thats a lot of boost on 10:1 compression, but i guess its all about tuning. oops haha forgot the topic...Victor X will flow better esp for turbo.
[Modified by LOwrestling2001, 1:47 AM 10/15/2002]
Old Oct 14, 2002 | 04:50 PM
John-GSR's Avatar
Victor X= =turbo
Skunk2= =NA
Good luck with your motor. Post some dyno's later. Hondata stage3? for ecu tuning.
Old Oct 14, 2002 | 05:11 PM
Acuracy's Avatar
New User
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (LOwrestling2001)
alot of people say that....but ive seen gsrs with 10:1 wth DFi pushing same numbers i wanna push...thas where i get my numbers from..i mean your rite its all bout tuning
...so the victor X with the secondaries is the way to go??
thanks
Old Oct 14, 2002 | 05:54 PM
Acuracy's Avatar
New User
Victor X= =turbo
Skunk2= =NA
thanks man...i will be sure to hit up a dyno and post numbers as soon as the motor is built and broken in......no im not using the hondata unit..im using the accel dfi...i wanted a gen 7 but i guess i gotta settle for a gen 6....
so another vote for victor x....anyone with personal expierances???...thanks
Travis
Old Oct 14, 2002 | 06:44 PM
Rob Dizzle's Avatar
unfortunaetly there is not much info at all as far as dyno charts go betweent those 2 products
everyone has their own prefernce. But on most na setups people loose hp from the jg vs skunk2
I would call the manufacturer and see if they have any dynos of comparing the two, or comparing thiers vs stock
good luck with your new setup
Old Oct 14, 2002 | 07:54 PM
Acuracy's Avatar
New User
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (Bob-DC2)
thanks Bob-DC-2....u know anyone who has the vic. x??
ttt
Old Oct 15, 2002 | 02:11 PM
Acuracy's Avatar
New User
anybody else?
Old Oct 30, 2002 | 07:07 AM
97ITR60's Avatar
i have the victor x and i am pleased with it over the stock type r especially for the turbo setup
victor x
Old Oct 30, 2002 | 07:48 AM
B18Redline's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (John-GSR)
Victor X= <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> =turbo
Skunk2= <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> =NA
I've heard victor x is better for n/a applications
Old Oct 30, 2002 | 08:03 PM
racermike27's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (Redline07)
I have the victor X on my Turbo GSR and i am very pleased with the performance i gained form it. But then again my entire motor setup is from JG Engine Dynamics so mayeb my it would run a little different on my car or other peoples cars (not to say my car is any better than anyone elses, but maybe this is a factor ). Although my cousin had the Skunk2 and it ran decent turbocharged but then he bought the Victor X and it made a hell of a lot more power. So i would say go with the Victor X if you are going BOOST!!
Old Oct 30, 2002 | 09:40 PM
Dee's Avatar
Dee
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (racermike27)
Get the SK2 if you want to save money for other items! I have been running a Turbo GSR sk2 mani setup for a year and I love it. The Sk2's ports are slight larger than the ITR but longer and shorter than the Victor X. The short runners on the Victor X make it a "must have" item for WOT ,high revving, high boost setups. With low boost street redline setups you might lose some much needed power in the low range and lower midrange but will have massive gains at WOT from about 6krpm to redline. Peak power isn't everything and usable power under the curve is more important on a street vehicle.
Old Nov 1, 2002 | 07:09 PM
Acuracy's Avatar
New User
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (Dee)
thanks man...i already have the skunk 2 on my gsr currently....but it looks like ima keep the skunk 2 for alittle while and run with that and use the money on other shyt like tuning the dfi and shyt...thanks alot guyz
anyone else have personal expierances with the victor X on their turbo car?
Old Nov 1, 2002 | 08:05 PM
Farnsrocket's Avatar
I have a Victor X.......had a Skunk, though I can't tell you any results yet.
I emailed you a pic of the two side by side......very impressive....the victor looks like it was made for turbo apps. later
Old Nov 2, 2002 | 06:38 PM
Acuracy's Avatar
New User
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (Farnsrocket)
thanks man!!....i never say them side by side before..damn the victor is a monstor compared to the skunk....thanks again
Old Nov 2, 2002 | 07:05 PM
no problem
Old Nov 2, 2002 | 08:32 PM
Cheez's Avatar
Victor Ownedz
Old Dec 11, 2002 | 09:35 AM
servion's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (Cheez)
I'm in a similar situation... I've got a turbo b18c hon hondata, boosting around 8 PSI. I will build it within a year... and I'm about to choose a new manifold. For a 8psi setup, would the victor X be worthwhile?
Old Dec 11, 2002 | 10:22 AM
B18Redline's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (servion)
yup, or a STR if you can afford it.
Old Dec 11, 2002 | 11:26 AM
gsrvx's Avatar
New User
the boosted motor setups I've seen @ importbuilders all seem to use the jg mani.
-Rod
Old Dec 11, 2002 | 12:59 PM
neo1z's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (RK)
im pretty confident that the victor x is a better manifold in both instances --- its just a higher quality intake manifold in general over skunk2, better in both applications.
Old Dec 11, 2002 | 01:31 PM
B18Redline's Avatar
Yeah, don't get me wrong, JG is great for all motor or turbo. I read a mag where someone gained upwards of 30-40 hp with the addition of the JG (victor x) manifold.
Old Dec 11, 2002 | 03:43 PM
threatcon13's Avatar
New User
good to see that youre running decent compression with the turbo. with tuning everything will be fine. youre gonna be making some insane power.
Old Dec 11, 2002 | 04:30 PM
Rob Dizzle's Avatar
Default Re: Victor X Vs. Skunk 2 in turbo Gsr (ALLMOTORDC2)
sgt LOST power with the jg manifold
he has 245whp+
keep this to turbo only.
i say, still stick with skunk2 even though there service and customer support sucks
jdmb16turbo
Feb 28, 2009 05:03 AM
longshot
Oct 16, 2008 12:51 PM
gsr95
Apr 13, 2008 09:53 PM
Zero Turbo
11
Feb 26, 2008 04:22 PM
mikemskater
Apr 19, 2007 12:24 PM
