98 gsr doing some test now no start
Old Jun 18, 2012 | 07:50 PM
bonjoey's Avatar
Default 98 gsr doing some test now no start
I have been trying to figure out a head noise between 2500-4000 rpm since I got this car about 2 weeks ago. Today I tried to remove each spark plug wires to see if the knocking will go away (old trick to check rod bearing), then after I remove no.2 wire the engine went to a stall. Now it won't start. I've got no spark on the spark plug, and no spark on the coil. When I tested the ignitor using a test light on the negative, it just stay lit while cranking. Do you guys think both ignitor and coil are bad?
PS. All fuses are good and fuel pump primes.
Thanks
Old Jun 18, 2012 | 08:06 PM
pompom's Avatar
Default Re: 98 gsr doing some test now no start
did you ground the wires while you were testing them?
Old Jun 18, 2012 | 08:11 PM
bonjoey's Avatar
Yes. Also I've heard you can install b18b1 dizzy on gsr right?
Just wondering if the coil and ignitor are also the same.
Old Jun 18, 2012 | 10:20 PM
Solster's Avatar
9 time out of 10 if you pull the wires on a Honda that is runing and you suddenly losse spark completly you ether fried the ICM or ECU
i know the coil is the same not sure on the ICM
Old Jun 19, 2012 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
You probably fried the coil, but the two should be interchangeable
http://www.team-integra.net/forum/bl...eshooting.html
Old Jun 19, 2012 | 08:19 PM
bonjoey's Avatar
Got a coil and icm from civic and replaced it, car is working now. Thx
Old Jun 19, 2012 | 08:31 PM
NemesisCBR's Avatar
From a civic? Hm thats gonna be useful info down the line.
Old Jun 19, 2012 | 08:35 PM
bonjoey's Avatar
The ignitor are all the same, just keep the heat sink, the coil is the same.
JuniorDDavis
41
Mar 5, 2012 12:43 PM
GSR_EJ2
16
Sep 3, 2009 07:02 AM
AznBlueBoy
Sep 8, 2006 08:21 PM
98coupe
Aug 30, 2005 05:22 PM
s2kkk
20
Apr 15, 2004 11:12 AM
