compressor wheel touching housing
Old Jun 16, 2012 | 11:14 PM
ninjaturtleEG's Avatar
Default compressor wheel touching housing
Hey I got a used turbo with very minimal shaft play. When i spin the compressor wheel it does not touch the housing. However, i can push the wheel enough to the left so that when i spin it then, I"ll hear a ping sound, but thats when im sort of forcing it, if i let it spin naturally then it wont touch. The turbo is not lubricated right now so i heard that there would be more shaft play than usual. Is this ok? thanks
Old Jun 17, 2012 | 12:23 AM
EsotericImage's Avatar
Retired Moderator
Default Re: compressor wheel touching housing
Not OK
hope you got it for cheap as a rebuild is needed
Old Jun 17, 2012 | 12:51 AM
ah ok. But the compressor fins look brand new and there are absolutely no nicks, chips, or bends on the fins. The guy i bought it from said it has been rebuilt 2000km ago. I think it might still be ok?
Also, just took a closer look inside the housing, there are no scratches in the housing, besides the new ones that i just created by pushing and spinning the wheel against it and its only in that section about less than an inch long.
Old Jun 17, 2012 | 06:33 AM
SiRCiviC94's Avatar
it should be a smooth turbine with no way of touching anything. maybe tighten up the wheel if possible? I put 10k on an ebay turbo it has very minimal shaft play (normal play imo)
Old Jun 17, 2012 | 06:40 AM
TheShodan's Avatar
Moderator
add a small bit of oil, then rotate it again. If you have to FORCE it to touch, its still usable but has dry bearings. That doesn't mean it necessarily needs a rebuild.
Old Jun 17, 2012 | 07:32 AM
xile6's Avatar
Add some oil and use a vaccum/shopvac to blow /suck on the exhaust side. Watch the compressor side.
Note vaccum the exhaust downpipe side, or blow the manifold port.
Done it tons of times to check old turbos. But it should not touch. If it does the bearing has to much play.
Old Jun 17, 2012 | 03:38 PM
Ok I'm going to put oil in and see. Thanks for the suggestions. How much oil should i put in? enough so that the oil level is above the shaft?
Old Jun 17, 2012 | 07:45 PM
Retired Moderator
Hmm, good to know..
I figured there was shaft play that would only get worse.. thx for the tech
Old Jun 18, 2012 | 02:04 PM
Hello, so I've narrowed it down more, the sound of scraping I'm hearing is coming from the turbine side, not the compressor.
motoxxxman
Jun 9, 2017 06:25 PM
tagperformance
Feb 3, 2012 02:35 AM
VTECth1s
Sep 9, 2011 01:19 PM
mildly.interesting
Jan 21, 2004 02:05 PM
