compressor wheel issues...
Old Jan 21, 2004 | 10:06 AM
mildly.interesting's Avatar
Default compressor wheel issues...
ok, I got a new snail fairly cheap, and when I get it and look at it I see this...
well not this one exactly, but the compressor wheel isn't as claose to the housing as most turbos I have seen. What are the conseqences of this? It spins free w/ no shaft play, looks brand new on the inside, but it just doesn't seem to be as close a tolerance as most I've seen.
the housing does look a little older than the exhaust side, so maybe somebody swapped em out, but will it effect performance?
Old Jan 21, 2004 | 10:10 AM
b18bturbo's Avatar
Default Re: compressor wheel issues... (mildly interesting)
looks like someone put a larger hosuing on the turbo. it should be fairly tite clearances
Old Jan 21, 2004 | 10:12 AM
Default Re: compressor wheel issues... (b18bturbo)
I thought so, how will this effect spooling and what-not?
Old Jan 21, 2004 | 10:47 AM
paulzy's Avatar
I've never tried running a turbo with a smaller wheel than the rated housing...I wouldn't have the nerve to either
Old Jan 21, 2004 | 11:03 AM
rudebwoy's Avatar
Default Re: (Paul_Vang)
I think it will not pull air as strong as the correct housing, it would be like drinking through a straw that has a hole in it. no pressure
Old Jan 21, 2004 | 02:05 PM
Default Re: (rudebwoy)
indeed you are correct sir! after we bolted it up, I would only pull about 9 lbs under full throttle, which in comparison to the 16 lbs I was pulling before, seemed sort of weak.
motoxxxman
Jun 9, 2017 06:25 PM
ninjaturtleEG
Jun 18, 2012 02:04 PM
tagperformance
Feb 3, 2012 02:35 AM
VTECth1s
Sep 9, 2011 01:19 PM
turbodano
Mar 7, 2010 12:24 AM
