Vtec issue
Old Jun 16, 2012 | 10:45 AM
jdmef69's Avatar
Default Vtec issue
So I finally hooked up vtec and the engine light turned off but my rev limiter is 4500 won't go over that. Any sugeations
Old Jun 16, 2012 | 10:48 AM
villc713's Avatar
Default Re: Vtec issue
Had the same problem with my gsr and my ls can and may be your map sensor, or your tps sensor thinking it's in Wot
Old Jun 16, 2012 | 10:50 AM
jdmef69's Avatar
Obd1 p28 b16 in my ef
Old Jun 16, 2012 | 10:52 AM
jdmef69's Avatar
Hmm possibly I guess this is my first vtec Honda lol always had non vtec
Old Jun 16, 2012 | 10:57 AM
villc713's Avatar
Some people say it can be the dizzy also but I've tried the dizzy trick on the ls and it didn't work but for some odd reason it went away, on the gsr it was a wiring problem, so I'd say check your grounds and make sure all your wires are where they need to be. Also reset or switch ecu's with somebody to try and see if that fixes your problem.
Old Jun 16, 2012 | 07:07 PM
stackedhouse's Avatar
Haha I had that problem in my b16.... My chip fell out of my Ecu... So it was running in limp mode
Old Jun 16, 2012 | 09:50 PM
jdmef69's Avatar
I will check my chip.
Old Jun 17, 2012 | 08:17 AM
Nooch's Avatar
Check engine light came ON? Or turned off? Why was it on if it just turned off?
Old Jun 17, 2012 | 11:49 PM
Stunna MIKE's Avatar
check the speed sensor, also does it have a 2-step ?
Old Jun 18, 2012 | 03:12 PM
jdmef69's Avatar
Yes it has two step. I realize my speedo is not working. I did the integra cluster swap with electronic Vss and the speedo is not working. Didn't realize that i needed it. Basically two step is not dis engaging. Once I hook up the Vss problem should go away.
Old Jun 18, 2012 | 03:13 PM
villc713's Avatar
Yes it should you would need a electronic vssand just extend the wires.
Old Jun 18, 2012 | 03:52 PM
91EFH22's Avatar
^^^^ What he said!
Old Jun 18, 2012 | 04:13 PM
jdmef69's Avatar
Ok so I hooked the wires up like they are suppose to be but when I turn my key to the on position the mph goes up to 40. Even when the Vss is not installed the speed goes to 40 mph. I triple
Checked wires. Can the cluster be had and cause this?
Old Jun 18, 2012 | 06:43 PM
91EFH22's Avatar
Def a wiring issue, one of the three wires for the VSS is backwards...
Old Jun 18, 2012 | 07:07 PM
villc713's Avatar
I say return to a cable operated cluster from a ef and cable speed sensor, just cuz vie had that problem on a accord and I'm thinking your cluster is bad.
integraluva04
Jun 29, 2008 10:27 AM
CeeJayy
Jul 27, 2007 01:36 PM
lsvtecna
Jul 23, 2006 10:55 PM
xxwhixx
Nov 7, 2005 12:23 AM
crxkenny
Dec 21, 2002 08:10 AM
