HELP! 94 Civic - stalls and complete electrical power loss
Old Jun 14, 2012 | 05:05 PM
Urikg's Avatar
Default HELP! 94 Civic - stalls and complete electrical power loss
I have a 94 V Tech Honda Civic which I love. Since I bought it I've had to change the distributor 3 times because I've been left on the street. The car just powers down while driving, giving the car has was useless and non of the elctricals worked. I recently just put in a third (new) distributor in and drive for the first time without any actual problems.
My issue is that I don't have any confidence while driving the car because I'm scared that it will power off again. Is there anything else that can possibly be causing the problem and/or is there anything I can do to alter the outcome this time?
Thanks for any and all responses!
Old Jun 14, 2012 | 06:22 PM
Former User's Avatar
Default Re: HELP! 94 V-Tech electrical issues
A bad distributor would not cause the car to lose all electrical power. And the fact that you have already installed three distributors tells you they're not the problem.
Start here:
-test the ignition switch.
-clean and tighten the battery connectors and the battery ground wire attached to the chassis.
Old Jun 14, 2012 | 06:25 PM
Civic2Fast's Avatar
sounds kind of silly, but my buddy had the exact same problem... he claimed to always need a jump for his car after it would die... he told me about the problem... I went out and tightened his battery terminals... no problem at all since then
Old Jun 14, 2012 | 06:26 PM
Civic2Fast's Avatar
or I can be a dummy and post the same thing after ron, lol my bad
Old Jun 18, 2012 | 03:28 AM
Urikg's Avatar
Default Re: HELP! 94 Civic - stalls and complete electrical power loss
Car left me stranded this weekend again. I was driving home from work and all off a sudden the RPM went from 2000 to 0. The radio, headlights, wipers and a/c still functioned but the car itself wouldn't function.
I try to start the car but car again but it sounds like it wants to start but it won't spark and turn on. As I turn the key to start the at the distributor makes a rattling sound, another fried piece.
Idk what is frying my new distributors.
Old Jun 18, 2012 | 04:49 AM
As you're not taking any advice, you probably should pay a shop to fix your car.
NotAJDMFanBoy
Jul 24, 2011 05:05 PM
csb93082
May 5, 2008 09:50 AM
Aralliius
Mar 2, 2008 02:11 PM
Hondasaurs
Oct 23, 2002 02:05 PM
dinosa21
Oct 5, 2002 07:12 PM
