How to install vband wastegate
Old Jun 14, 2012 | 02:58 PM
ay_billy's Avatar
Default How to install vband wastegate
I wish I had pics, ill try to load them in a bit.
Im having trouble with the adapter piece that goes between the wastegate and vband flange, i can put it together, but it takes a lot of pressure and im pushing in the plunger. Does this sound right?
Old Jun 14, 2012 | 03:02 PM
EsotericImage's Avatar
Retired Moderator
Default Re: How to install vband wastegate
doesnt sound right at all..
one part gets welded to the WG opening, the other is part of the WG. Use the collar to squeeze the 2 together. the more you tighten the collar, the more sealing.
If you have any questions, just google image V band
Old Jun 14, 2012 | 03:05 PM
ay_billy's Avatar
I understand the vband ouside part, buth theres an inside piece. Unless I dont need the piece?
Old Jun 14, 2012 | 03:06 PM
sanman000719's Avatar
there is a firing ring
post pix
Old Jun 14, 2012 | 03:11 PM
Retired Moderator
Old Jun 14, 2012 | 03:12 PM
ay_billy's Avatar
This thing has to go between the wastegate and manifold right?
one of those needs to be welded to the manifold the other to the gate
Old Jun 14, 2012 | 03:14 PM
ay_billy's Avatar
ill go in a bit to take pics
Old Jun 14, 2012 | 03:18 PM
Retired Moderator
the one on the WG should already be on, so u have just 1 ring and a collar.
So, in the pic, the bottom gets welded to the WG outlet.
The one on the side gets welded to the dump tube.
I cant explain it any easier
Old Jun 14, 2012 | 03:25 PM
ay_billy's Avatar
My manifold and gate are vband, but I think the piece i am confused about is the sealing ring and how it fits
Old Jun 14, 2012 | 04:08 PM
Retired Moderator
Just like that.
Old Jun 15, 2012 | 07:26 AM
paulzy's Avatar
That's ring is called a valve seat. You need to preload the valve and seat to install the wastegate.
Old Jun 15, 2012 | 08:02 AM
ay_billy's Avatar
Thanks, the other guy had me thinking I was stupid or something.
How much pressure should it take?
Old Jun 18, 2012 | 01:09 PM
paulzy's Avatar
should'nt take much at all. It really depends on the spring(s) you have in teh wastegate
Old Jun 18, 2012 | 02:53 PM
BEfab's Avatar
what brand gate are you running?
Old Jun 19, 2012 | 03:29 PM
Dc4LsTeG's Avatar
EK9
I think your talking about something different then what the OP is talking about
Old Jun 19, 2012 | 03:55 PM
jdm inc's Avatar
im taking it that its a tial brand?
W O T
Nov 13, 2005 11:58 PM
ultradx
Aug 11, 2005 12:24 PM
94lsboost
Mar 29, 2005 05:31 PM
a z n t a k
Feb 21, 2004 08:09 PM
black2kgsr
Jun 6, 2003 07:32 PM
