oil in cylinders
Old Jun 14, 2012 | 12:47 PM
94_DC's Avatar
Default oil in cylinders
94 del sol with LS swap. Has new valve cover gasket and new tube seals. Car bogs before 3k then opens up. have no idea what else could cause this...
Old Jun 14, 2012 | 12:53 PM
grumblemarc's Avatar
The Grumpiest
Default Re: oil in cylinders
Rings. Compression test it. Timing. Check mechanical and ignition. Tune up. Do one if you haven't.
Old Jun 14, 2012 | 02:55 PM
Nbboy7's Avatar
I would say timing also
Old Jun 14, 2012 | 04:02 PM
hondaguy777's Avatar
Yeah, compression test. Dry and wet. This will tell you if you have bad rings.
Old Jun 14, 2012 | 04:18 PM
92lxsleeper's Avatar
if the compression comes out fine then its the valve seals
Old Jun 14, 2012 | 06:10 PM
Civic2Fast's Avatar
mostly true... do a leakdown also if compression is good
Old Jun 15, 2012 | 12:16 PM
94_DC's Avatar
Ill do a comp test but since there is oil going into the cylinders im sure it will be high anyways. I got a spare head thats good laying around ill swap that out and see if its the prob.
Old Jun 15, 2012 | 12:19 PM
Dc4LsTeG's Avatar
EK9
Why just do a leak down test
Old Jun 15, 2012 | 02:13 PM
EsotericImage's Avatar
Retired Moderator
so you have excess oil on the plugs?
before removing the head, do the above tests and then we can narrow it down
Whatislove
Honda Civic (2001 - 2005)
Sep 6, 2011 02:30 PM
vinuneuro
Apr 25, 2007 10:13 AM
efcivic757
15
Apr 14, 2005 06:27 PM
blackeg
Mar 28, 2005 06:10 AM
Jet Black
Jul 22, 2003 07:41 AM
