Clutch grinds while engaging. Also Two clutch points...help!
Old Jun 13, 2012 | 11:32 AM
Solstic's Avatar
Default Clutch grinds while engaging. Also Two clutch points...help!
When I engage first gear i hear a grinding noise but once the clutch peddle is fully depressed the sound is gone. I heard it could be the throwout bearing or maybe input shaft bearing. Also another problem im facing is that when i let go of the clutch from the floor it feels as though the clutch grabs right away but as i further depress the clutch it goes back the neutral, and even further up ,about halfway where my clutch point is supposed to be, it engages but with the grinding noise i mentioned above.
Ive heard that normally, a bad throw out bearing makes noise with the clutch pedal depressed, whereas a bad input shaft bearing will make noise with the clutch engaged.
Old Jun 13, 2012 | 11:34 AM
Former User's Avatar
Default Re: Clutch grinds while engaging. Also Two clutch points...help!
Most likely this^
Probot
Apr 18, 2007 07:00 AM
streetjdm
Jan 17, 2005 03:20 PM
H.crx-si
Jul 31, 2004 06:27 PM
killerslp
Jan 25, 2004 05:35 PM
turbocivicef
Apr 18, 2003 05:29 AM
