d series turbo build looking for help
Old Jun 11, 2012 | 07:56 PM
em1 si-t's Avatar
Default d series turbo build looking for help
hi i was just looking for some help on building my d16y8 bottem end i will be running eagle rods with wisco 8.5:1 compression pistons with apr headstuds and rod bolts it will also be bored .20 over and would like to run 15-25 psi of boost any tips or info for oil pump or rod and main bearings and if i should run a block gaurd thanks
Dylon
Old Jun 11, 2012 | 08:04 PM
egb18dx's Avatar
Default Re: d series turbo build looking for help
You'll need to port and shim the oil pump. Not sure if there is a pump out there that already comes that way. And you can't go to wrong with acl bearings.
Old Jun 11, 2012 | 08:10 PM
em1 si-t's Avatar
will this increase my flow or just pressure? because if it gives more pressure but not flow its not worth putting the stress on the oil pump
Old Jun 11, 2012 | 08:24 PM
egb18dx's Avatar
The y8 doesn't flow as good as the z6 pump. If you don't port it then you'll more than likely spin a bearing.
Old Jun 12, 2012 | 03:46 AM
grumblemarc's Avatar
The Grumpiest
Differences between the Y8 and Z6 pump are minimal. It's the crankshaft you have to worry about. One oiling hole per journal as opposed to two. You could source a Z6 crank like I did for the next build. Right now I'm running a ported and shimmed pump on my Y8. I've never read up anything on "stressing" the oil pump. Did you make that up?
Old Jun 12, 2012 | 07:41 PM
em1 si-t's Avatar
i was reading it on anouthr forum that was saying the increase in pressure with out more flow would cause stress and break oil pump but that might have been for just shiming it and not porting it
Old Jun 12, 2012 | 07:43 PM
em1 si-t's Avatar
and also i was wondering if i would be better off finding a z6 block with a crank and just putting my y8 head on it seeing as it was just redone with all new upgraded spring retainers and valves?
Old Jun 12, 2012 | 09:19 PM
egb18dx's Avatar
The y's like to spin bearing z6 is pretty good.
Old Jun 13, 2012 | 03:11 AM
The Grumpiest
Where did you read that exactly? Link? I have never heard such a thing.
Old Jun 13, 2012 | 05:50 AM
boosted_D's Avatar
I have read bad things about shimming the oil pump also, not sure where though, maybe D-series.org
From what I gather if you have good bearing clearance and you just port the pump (no shimming) they work fine with no bearing failure, this is my plan.
But the inherint problem is with the oil passages in the crank, there are two ways to fix this.
1. swap to a z6 crank
2. have the machine shop very slightly port and chamfer the oil holes on the y8 crank.
I do not plan on doing this though, I'm going to port the pump only, and hope for the best as this seems to work fine from what I have read.
Old Jun 13, 2012 | 06:13 AM
tron_'s Avatar
10 Year Member
Get an endyn oil pump if you are running a y7/y8
Old Jun 13, 2012 | 07:41 AM
The Grumpiest
Ported and shimmed Y8 pump with Y8 crank. No issues for 3 years and running.
ReVeNgEd-SoN
Feb 29, 2012 07:36 AM
r0iand
Apr 27, 2010 07:11 PM
iwanttogofast
Apr 1, 2009 11:54 PM
jesimmers
May 15, 2007 07:29 PM
MAFDARK
Sep 21, 2006 08:20 AM
