1992 honda civic antenna help
Old Jun 11, 2012 | 07:18 PM
Jettplane's Avatar
Default 1992 honda civic antenna help
When I got my car, it had no antenna so I dont know where the antenna hole under the dash is. When I try inserting the antenna wire down the driver pillar from the roof, I dont know where it comes out. Does someone know where it comes out? I've been trying to look for it.
Old Jun 12, 2012 | 03:33 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1992 honda civic antenna help
Where else would it come out of? Like I said n the thread you bumped, it routes down the A-pillar then under the dash. There is only one hole and that's on the roof.
Old Jun 12, 2012 | 05:47 AM
MRGRIM's Avatar
R.I.P. Mark
take the kick panel off and look in the A pillar cavity
Old Jun 12, 2012 | 08:25 AM
NVturbo's Avatar
O.G. triple O.G.
^^ You don't have to remove the kick panel. The cavity ends at the height of the PGMFI relay. Use a "fish tape" or metal coathanger to pull the new antenna cable through.
Old Jun 12, 2012 | 01:00 PM
Jettplane's Avatar
Yes I am aware there is a hole on the roof because thats where im inserting the antenna from. I just need to know where it comes out under the dash. Be specific as to where it is because "under the dash" isn't helpful.
Old Jun 12, 2012 | 01:01 PM
Jettplane's Avatar
Where and what is that exactly?
Old Jun 12, 2012 | 01:04 PM
The Grumpiest
Where and what is what?
Dude. Get the new Antenna. Fish some wire down into the hole until it comes out the bottom of the A-pillar on the INSIDE of the car. Attach the wire, however you want, to the end of the new antenna and pull it through.
What is so hard about that?
Old Jun 12, 2012 | 01:08 PM
Jettplane's Avatar
First of all, "Where and what is that exactly?" wasn't in reply to you but okay. I'll try that though cause what I have done was fish the antenna wire down the pillar but I couldnt find it under the dash. I guess I need to use something thinner. Thanks.
Old Jun 12, 2012 | 01:09 PM
The Grumpiest
It's there. It didn't go to the phantom zone. If you have to start removing panels.
305_DB7ish
Mar 25, 2015 12:52 AM
awwsnap
Aug 21, 2005 08:00 AM
Zing
Aug 7, 2004 03:25 PM
crx_ef8
Feb 10, 2003 08:31 PM
Ef Whore
Audio / Security / Video
Dec 22, 2002 08:18 PM
