Swap or turbo?
I just bought a 97 civic dx which has the stock d16y7. I want more power because everything out there just stomps my 106 hp. My question is.. Should I spend the money to swap or just throw a turbo on it? If I do swap, what is the best way to go for the money/ horsepower? I'm new to Hondas any help is appreciated
i say turbo. ITs the route i went and love it.
Since you got a dx you should do a y8 manifold swap first and then turbo.
Also if its 100% stock, then the y8 manifold , ebay header, and a cat back will give you a small bump in power.
But over all a turbo will give you alot more.
Now swaping would one be to a b motor but the cost will be more then a custom turbo kit.
From: Pensacola, FL and every Court House in Louisiana
Both! Do you want stock reliability? If so than a swap is in your future. If you want more power regardless of how expensive it gets, then go turbo or both. I love my gsr swap, it is a blast to drive(go-cart on roids) but I bought it to go turbo and can't wait for more power.
You have a ton of reading to do before "throwing a turbo" on your car.
Here's a place to start
http://www.beesandgoats.com/boostfaq/g2icturbo.html
It'd be a hit and miss; turbo'ing a stock D can only take you so far.
If you do a lot more research; plan out your future spendings you can get some amazing numbers if planned right. Personally; i'm going to build up a B-series from the block up and run N/A for a while; then turbo it if available. Don't rush your car unless you have good reasons; and throwing a turbo into a DD without much knowledge of the works of it might not be the best thing to do.
I have a d16Y8 and I slapped a small turbo on it and love it. 210whp is a lot of power for a car that weighs in just over 2,000 lbs. Personally any more power would make it harder to drive.
OP if you have any more questions, please feel free to message me.
I also encourage you to read this:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/guide-answer-common-question-just-bought-civic-how-do-i-make-faster-2915974/
wound tight
30
May 22, 2007 05:19 PM
...B16s
