Exhaust nut stripped and won't come off
Old Jun 11, 2012 | 12:41 PM
Mishako129's Avatar
Default Exhaust nut stripped and won't come off
Hey guys. I'm here try to prepare my car for an engine removal. When I got to the part which tells me to remove the exhaust, I encountered something bewildering.
After trying to get the one of the 3 nuts off, the first one I tried stripped. This was after I used pb blaster and heat from a candle to make it budge.
I tried vice grips but they only stripped too.
Its kind of difficult to work where it is because it is directly connected to the cat.
I need help fast.
Thanks.
Old Jun 11, 2012 | 05:13 PM
Pagoda's Avatar
Default Re: Exhaust nut stripped and won't come off
Any room to get one of these in there?
Old Jun 11, 2012 | 05:20 PM
Thepowderblue's Avatar
Get it red hot and try. Or hammer a smaller socket on.
Can you get it with a grinder or drill the bolt out of the nut
Old Jun 11, 2012 | 07:37 PM
19Accord97's Avatar
Sears, lowes, etc has a socket that has teeth in it and becomes tighter and tighter the more it is turned so it doesn't matter if the bolt head is stripped or not.
The bolts for my exhaust/cat did the same thing. If you ever plan on removing them after replacement get some grade 10 ones.
Old Jun 11, 2012 | 09:02 PM
HonBeer's Avatar
Weld a nut to it. Use that nut to remove it.
Old Jun 12, 2012 | 03:48 AM
TouringAccord's Avatar
H-T Order of Merit
I believe a bolt-out is what you are referring to..
I have a set like this from Sears and have used it a few times on stripped nuts/bolts and have had good success with them.
Of course this only works if they have access to a welder.
Old Jun 12, 2012 | 05:56 PM
Mishako129's Avatar
Hey guys, sorry for not answering back but thank you for your answers. I was busy on this other forum with the same question... You can read my trials and errors here (with pics):
http://www.cb7tuner.com/vbb/showthread.php?t=191344
Old Jun 12, 2012 | 07:42 PM
19Accord97's Avatar
This is what I was referring to.
http://www.sears.com/grip-tite-17-pc...25000P?prdNo=6
Old Jun 14, 2012 | 06:41 AM
FateMorlock's Avatar
if it on the header u don't need to just the down pipe remove. it will clear and give u some thing to hold on to lol the header i mean
trader8825
Mar 28, 2013 08:52 PM
97civicgirl
16
Mar 8, 2011 11:47 AM
Leon Trout
Apr 25, 2010 07:27 PM
MysticAzn03
Feb 19, 2003 03:03 PM
RuskeR
Feb 15, 2003 10:30 PM
