Speedometer and Odometer Problem
Old Jun 10, 2012 | 09:39 PM
Ericdf132's Avatar
Default Speedometer and Odometer Problem
I have a 95 Civic Ex Coupe, 1.6 vtech I just recently acquired, and for starters my speedometer and odometer aren't working. What steps should I take to figure out what's wrong? All I know there is a sensor somewhere under my hood.
Old Jun 10, 2012 | 11:27 PM
FrodeyEJ1's Avatar
Default Re: Speedometer and Odometer Problem
Ure speed sensor could be shitting on you. Will be on tranny by ure starter. Make sure it's clean and waterproof( such as no open wires)
Old Jun 11, 2012 | 06:15 AM
crewcut1983's Avatar
If its the VSS, its easy to fix..Get your local auto parts store to scan it with a code reader...10-minute job...they can show you where it is too, if your unsure...
Old Jun 11, 2012 | 07:13 AM
angrysmileyface's Avatar
There is also the possibility that you have bad solder joints on back of the spedometer portion of the cluster. This problem has been addressed before. Search, there are probably at least 4 or 5 threads.
Old Jun 11, 2012 | 08:25 AM
noz79's Avatar
I have a 92 that had a similar issue but it wasn't the speed sensor, it was the wiring in the connector at the drivers side strut tower. Before you buy parts have them tested first but thats what you were going to do anyway. Give me a minute to look at some diagrams.
Old Jun 11, 2012 | 09:47 AM
noz79's Avatar
This should be all you need to know
Old Jun 13, 2012 | 06:21 PM
Jgreen94's Avatar
Thanks noz79 for the info. I'm having the same problem.
doubleoazn03
Sep 5, 2008 10:33 PM
DC2man
Mar 3, 2008 07:01 PM
silentblackhat
Dec 25, 2005 05:29 PM
hired gun
Dec 10, 2002 04:19 AM
Mike95lude
Feb 18, 2002 09:50 PM
